I have been trying to get this to run for a few days now. The wait some time for it to come up is a killer in a situation like this. I started out on a previous rpi4. Went to the HA website and did the download. Put the SD card in and it ran and stopped at the login screen. Can see it in on wired list of connections but couldn’t reach the site. Tried the 64 bit version. Still no go. Tried different SD cards. Still not able to reach the website. Found you could try previous versions. Tried 5.11, 5.10. 5.2 all 32 and 64 versions. Only once was I able to reach the site and I lost it while looking for an error. Even tried a new rpi4 and 64mb card. Suggestions?
Error that I was working with, the one time the site came up.
0-12-16 10:12:03 INFO (MainThread) [supervisor.homeassistant.core] Updating Home Assistant to version 2020.12.0
20-12-16 10:12:03 INFO (SyncWorker_4) [supervisor.docker.interface] Updating image homeassistant/raspberrypi3-homeassistant:0.118.5 to homeassistant/raspberrypi3-homeassistant:2020.12.0
20-12-16 10:12:03 INFO (SyncWorker_4) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi3-homeassistant with tag 2020.12.0.
20-12-16 10:12:18 ERROR (SyncWorker_4) [supervisor.docker.interface] Can’t install homeassistant/raspberrypi3-homeassistant:2020.12.0 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2020.12.0&fromImage=homeassistant%2Fraspberrypi3-homeassistant: Internal Server Error (“Get “https://registry-1.docker.io/v2/ ”: context deadline exceeded (Client.Timeout exceeded while awaiting headers)”).
I believe so. It was working when I used it for octoprint. I removed the SD card from it. Used etcher and flashed the HA put it back in the rpi and I can see it on my router.
I tried a different router and going wireless tonight. No change. Can’t reach the page from the computer. Can see the router has given it an address on this router as well.
I tried 5.10 again today and now I can reach it at the UI. If I click the blue dot I get this for an error:
Preparing Home Assistant
[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] udev.sh: executing…
[17:25:34] INFO: Update udev information
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[17:25:34] INFO: Starting local supervisor watchdog…
20-12-16 17:25:37 INFO (MainThread) [main] Initializing Supervisor setup
20-12-16 17:25:38 INFO (MainThread) [supervisor.docker.network] Can’t find Supervisor network, creating a new network
20-12-16 17:25:38 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry
20-12-16 17:25:38 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: raspberrypi4
20-12-16 17:25:38 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor homeassistant/armv7-hassio-supervisor with version 2020.12.7
20-12-16 17:25:38 INFO (SyncWorker_0) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
20-12-16 17:25:39 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
20-12-16 17:25:39 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
20-12-16 17:25:39 INFO (MainThread) [main] Setting up Supervisor
20-12-16 17:25:39 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
20-12-16 17:25:39 INFO (MainThread) [supervisor.host.info] Updating local host information
20-12-16 17:25:39 INFO (MainThread) [supervisor.host.services] Updating service information
20-12-16 17:25:39 INFO (MainThread) [supervisor.host.network] Updating local network information
20-12-16 17:25:41 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
20-12-16 17:25:41 INFO (MainThread) [supervisor.host] Host information reload completed
20-12-16 17:25:41 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {‘hassio-supervisor’}
20-12-16 17:25:41 INFO (MainThread) [supervisor.host.services] Reloading local service hassos-apparmor.service
20-12-16 17:25:41 INFO (SyncWorker_0) [supervisor.docker.interface] Found homeassistant/armv7-hassio-dns versions: [‘2020.11.0’]
20-12-16 17:25:41 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/armv7-hassio-dns with version 2020.11.0
20-12-16 17:25:41 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
20-12-16 17:25:43 INFO (SyncWorker_0) [supervisor.docker.dns] Starting DNS homeassistant/armv7-hassio-dns with version 2020.11.0 - 172.30.32.3
20-12-16 17:25:43 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
20-12-16 17:25:43 INFO (SyncWorker_0) [supervisor.docker.interface] Found homeassistant/armv7-hassio-audio versions: [‘17’]
20-12-16 17:25:43 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/armv7-hassio-audio with version 17
20-12-16 17:25:43 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
20-12-16 17:25:45 INFO (SyncWorker_0) [supervisor.docker.audio] Starting Audio homeassistant/armv7-hassio-audio with version 17 - 172.30.32.4
20-12-16 17:25:45 INFO (SyncWorker_1) [supervisor.docker.interface] Found homeassistant/armv7-hassio-cli versions: [‘2020.11.1’]
20-12-16 17:25:45 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/armv7-hassio-cli with version 2020.11.1
20-12-16 17:25:45 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
20-12-16 17:25:46 INFO (SyncWorker_0) [supervisor.docker.cli] Starting CLI homeassistant/armv7-hassio-cli with version 2020.11.1 - 172.30.32.5
20-12-16 17:25:46 INFO (SyncWorker_1) [supervisor.docker.interface] Found homeassistant/armv7-hassio-observer versions: [‘2020.10.1’]
20-12-16 17:25:46 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/armv7-hassio-observer with version 2020.10.1
20-12-16 17:25:46 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
20-12-16 17:25:48 INFO (SyncWorker_0) [supervisor.docker.observer] Starting Observer homeassistant/armv7-hassio-observer with version 2020.10.1 - 172.30.32.6
20-12-16 17:25:48 INFO (SyncWorker_1) [supervisor.docker.interface] Found homeassistant/armv7-hassio-multicast versions: [‘3’]
20-12-16 17:25:48 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/armv7-hassio-multicast with version 3
20-12-16 17:25:48 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
20-12-16 17:25:49 INFO (SyncWorker_0) [supervisor.docker.multicast] Starting Multicast homeassistant/armv7-hassio-multicast with version 3 - Host
20-12-16 17:25:49 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
21-02-28 17:21:16 INFO (MainThread) [supervisor.plugins] dns does not have the latest version 2021.01.0, updating
21-02-28 17:21:16 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image homeassistant/armv7-hassio-dns:2020.11.0 to homeassistant/armv7-hassio-dns:2021.01.0
21-02-28 17:21:16 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image homeassistant/armv7-hassio-dns with tag 2021.01.0.
21-02-28 17:21:32 ERROR (SyncWorker_0) [supervisor.docker.interface] Can’t install homeassistant/armv7-hassio-dns:2021.01.0 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2021.01.0&fromImage=homeassistant%2Farmv7-hassio-dns: Internal Server Error (“Get “https://registry-1.docker.io/v2/”: context deadline exceeded (Client.Timeout exceeded while awaiting headers)”).
21-02-28 17:21:32 ERROR (MainThread) [supervisor.plugins.dns] CoreDNS update failed
21-02-28 17:21:32 ERROR (MainThread) [supervisor.plugins] Can’t update dns to 2021.01.0, the Supervisor healthy could be compromised!
21-02-28 17:21:32 INFO (MainThread) [supervisor.plugins] audio does not have the latest version 2021.02.1, updating
21-02-28 17:21:32 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image homeassistant/armv7-hassio-audio:17 to homeassistant/armv7-hassio-audio:2021.02.1
21-02-28 17:21:32 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image homeassistant/armv7-hassio-audio with tag 2021.02.1.
21-02-28 17:21:47 ERROR (SyncWorker_1) [supervisor.docker.interface] Can’t install homeassistant/armv7-hassio-audio:2021.02.1 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2021.02.1&fromImage=homeassistant%2Farmv7-hassio-audio: Internal Server Error (“Get “https://registry-1.docker.io/v2/”: context deadline exceeded”).
21-02-28 17:21:47 ERROR (MainThread) [supervisor.plugins.audio] Audio update failed
21-02-28 17:21:47 ERROR (MainThread) [supervisor.plugins] Can’t update audio to 2021.02.1, the Supervisor healthy could be compromised!
21-02-28 17:21:47 INFO (MainThread) [supervisor.plugins] cli does not have the latest version 2021.02.1, updating
21-02-28 17:21:47 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image homeassistant/armv7-hassio-cli:2020.11.1 to homeassistant/armv7-hassio-cli:2021.02.1
21-02-28 17:21:47 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image homeassistant/armv7-hassio-cli with tag 2021.02.1.
21-02-28 17:22:02 ERROR (SyncWorker_0) [supervisor.docker.interface] Can’t install homeassistant/armv7-hassio-cli:2021.02.1 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2021.02.1&fromImage=homeassistant%2Farmv7-hassio-cli: Internal Server Error (“Get “https://registry-1.docker.io/v2/”: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)”).
21-02-28 17:22:02 ERROR (MainThread) [supervisor.plugins.cli] CLI update failed
21-02-28 17:22:02 ERROR (MainThread) [supervisor.plugins] Can’t update cli to 2021.02.1, the Supervisor healthy could be compromised!
21-02-28 17:22:02 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
21-02-28 17:22:02 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
21-02-28 17:22:02 INFO (SyncWorker_0) [supervisor.docker.interface] Found homeassistant/raspberrypi4-homeassistant versions: [‘landingpage’]
21-02-28 17:22:02 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to homeassistant/raspberrypi4-homeassistant with version landingpage
21-02-28 17:22:02 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
21-02-28 17:22:02 INFO (MainThread) [supervisor.homeassistant] Update pulse/client.config: /data/tmp/homeassistant_pulse
21-02-28 17:22:02 INFO (SyncWorker_1) [supervisor.docker.homeassistant] Starting Home Assistant homeassistant/raspberrypi4-homeassistant with version landingpage
21-02-28 17:22:03 INFO (MainThread) [supervisor.hassos] Detect HassOS 5.10 / BootSlot A
21-02-28 17:22:03 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
21-02-28 17:22:03 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/homematic/config.json: does not match regular expression for dictionary value @ data[‘schema’][‘hmip’][0][‘device’]. Got ‘device(subsystem=tty)’
does not match regular expression for dictionary value @ data[‘schema’][‘rf’][0][‘device’]. Got ‘device(subsystem=tty)’
required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/ssh/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/zwave/config.json: does not match regular expression for dictionary value @ data[‘schema’][‘device’]. Got ‘device(subsystem=tty)’
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/google_assistant/config.json: required key not provided @ data[‘boot’]. Got None
required key not provided @ data[‘startup’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/mosquitto/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/rpc_shutdown/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/duckdns/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/almond/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/tellstick/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/dhcp_server/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/dnsmasq/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/nginx_proxy/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/vlc/config.json: Service vlc_telnet not found @ data[‘discovery’][0]. Got ‘vlc_telnet’
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/samba/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/ada/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/deconz/config.json: does not match regular expression @ data[‘devices’][0]. Got ‘/dev/mem’
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/configurator/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/zwave_js/config.json: Service zwave_js not found @ data[‘discovery’][0]. Got ‘zwave_js’
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/core/mariadb/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/traccar/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/ssh/config.json: does not match regular expression @ data[‘devices’][0]. Got ‘/dev/mem’
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/jupyterlab/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/tor/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/chrony/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/portainer/config.json: required key not provided @ data[‘boot’]. Got None
required key not provided @ data[‘options’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/unifi/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/tasmoadmin/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/tautulli/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/ftp/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/airsonos/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/node-red/config.json: does not match regular expression @ data[‘devices’][0]. Got ‘/dev/mem’
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/zwavejs2mqtt/config.json: Service zwave_js not found @ data[‘discovery’][0]. Got ‘zwave_js’
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/influxdb/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/vscode/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/motioneye/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/lutron-cert/config.json: required key not provided @ data[‘options’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/example/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/plex/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/grafana/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/aircast/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/grocy/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/esphome/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/adguard/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/bookstack/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/wireguard/config.json: does not match regular expression @ data[‘devices’][0]. Got ‘/dev/net/tun’
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/appdaemon/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/adb/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/zwave2mqtt/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/nut/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/glances/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/phpmyadmin/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/bitwarden/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/zerotier/config.json: does not match regular expression @ data[‘devices’][0]. Got ‘/dev/net/tun’
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/thelounge/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/sqlite-web/config.json: required key not provided @ data[‘boot’]. Got None
required key not provided @ data[‘schema’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/home-panel/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 WARNING (MainThread) [supervisor.store.data] Can’t read /data/addons/git/a0d7b954/nginxproxymanager/config.json: required key not provided @ data[‘boot’]. Got None
21-02-28 17:22:06 INFO (MainThread) [supervisor.store] Loading add-ons from store: 9 all - 9 new - 0 remove
21-02-28 17:22:06 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
21-02-28 17:22:06 INFO (MainThread) [supervisor.snapshots] Found 0 snapshot files
21-02-28 17:22:06 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
21-02-28 17:22:06 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
21-02-28 17:22:06 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
21-02-28 17:22:06 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-02-28 17:22:06 ERROR (MainThread) [supervisor.homeassistant.api] Can’t update Home Assistant access token!
21-02-28 17:22:06 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
21-02-28 17:22:06 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-02-28 17:22:06 INFO (MainThread) [main] Running Supervisor
21-02-28 17:22:06 INFO (MainThread) [supervisor.hassos] Rauc: A - marked slot kernel.0 as good
21-02-28 17:22:06 INFO (MainThread) [supervisor.supervisor] Update Supervisor to version 2021.02.11
21-02-28 17:22:06 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image homeassistant/armv7-hassio-supervisor with tag 2021.02.11.
21-02-28 17:22:21 ERROR (SyncWorker_0) [supervisor.docker.interface] Can’t install homeassistant/armv7-hassio-supervisor:2021.02.11 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2021.02.11&fromImage=homeassistant%2Farmv7-hassio-supervisor: Internal Server Error (“Get “https://registry-1.docker.io/v2/”: context deadline exceeded”).
21-02-28 17:22:21 ERROR (MainThread) [supervisor.supervisor] Update of Supervisor failed!
21-02-28 17:22:21 CRITICAL (MainThread) [supervisor.core] Can’t update Supervisor! This will break some Add-ons or affect future version of Home Assistant!
21-02-28 17:22:21 INFO (MainThread) [supervisor.addons] Phase ‘AddonStartup.INITIALIZE’ starting 0 add-ons
21-02-28 17:22:21 INFO (MainThread) [supervisor.addons] Phase ‘AddonStartup.SYSTEM’ starting 0 add-ons
21-02-28 17:22:22 INFO (MainThread) [supervisor.addons] Phase ‘AddonStartup.SERVICES’ starting 0 add-ons
21-02-28 17:22:22 INFO (MainThread) [supervisor.core] Skiping start of Home Assistant
21-02-28 17:22:22 INFO (MainThread) [supervisor.addons] Phase ‘AddonStartup.APPLICATION’ starting 0 add-ons
21-02-28 17:22:22 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
21-02-28 17:22:22 INFO (MainThread) [supervisor.misc.hwmon] Started Supervisor hardware monitor
21-02-28 17:22:22 INFO (MainThread) [supervisor.core] Supervisor is up and running
21-02-28 17:22:22 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
21-02-28 17:22:22 INFO (MainThread) [supervisor.host.info] Updating local host information
21-02-28 17:22:22 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-homeassistant:landingpage to homeassistant/raspberrypi4-homeassistant:2021.2.3
21-02-28 17:22:22 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-homeassistant with tag 2021.2.3.
21-02-28 17:22:22 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
21-02-28 17:22:22 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
21-02-28 17:22:22 INFO (MainThread) [supervisor.host.services] Updating service information
21-02-28 17:22:22 INFO (MainThread) [supervisor.host.network] Updating local network information
21-02-28 17:22:24 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
21-02-28 17:22:24 INFO (MainThread) [supervisor.host] Host information reload completed
21-02-28 17:22:37 ERROR (SyncWorker_0) [supervisor.docker.interface] Can’t install homeassistant/raspberrypi4-homeassistant:2021.2.3 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2021.2.3&fromImage=homeassistant%2Fraspberrypi4-homeassistant: Internal Server Error (“Get “https://registry-1.docker.io/v2/”: context deadline exceeded (Client.Timeout exceeded while awaiting headers)”).
21-02-28 17:22:37 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-28 17:23:07 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-homeassistant:landingpage to homeassistant/raspberrypi4-homeassistant:2021.2.3
21-02-28 17:23:07 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-homeassistant with tag 2021.2.3.
21-02-28 17:23:32 ERROR (SyncWorker_1) [supervisor.docker.interface] Can’t install homeassistant/raspberrypi4-homeassistant:2021.2.3 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2021.2.3&fromImage=homeassistant%2Fraspberrypi4-homeassistant: Internal Server Error (“Get “https://registry-1.docker.io/v2/homeassistant/raspberrypi4-homeassistant/manifests/2021.2.3”: Get “https://auth.docker.io/token?scope=repository%3Ahomeassistant%2Fraspberrypi4-homeassistant%3Apull&service=registry.docker.io”: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)”).
21-02-28 17:23:32 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-28 17:24:02 INFO (SyncWorker_4) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-homeassistant:landingpage to homeassistant/raspberrypi4-homeassistant:2021.2.3
21-02-28 17:24:02 INFO (SyncWorker_4) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-homeassistant with tag 2021.2.3.
21-02-28 17:24:17 ERROR (SyncWorker_4) [supervisor.docker.interface] Can’t install homeassistant/raspberrypi4-homeassistant:2021.2.3 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2021.2.3&fromImage=homeassistant%2Fraspberrypi4-homeassistant: Internal Server Error (“Get “https://registry-1.docker.io/v2/”: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)”).
21-02-28 17:24:17 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-28 17:24:47 INFO (SyncWorker_5) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-homeassistant:landingpage to homeassistant/raspberrypi4-homeassistant:2021.2.3
21-02-28 17:24:47 INFO (SyncWorker_5) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-homeassistant with tag 2021.2.3.
21-02-28 17:25:02 ERROR (SyncWorker_5) [supervisor.docker.interface] Can’t install homeassistant/raspberrypi4-homeassistant:2021.2.3 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2021.2.3&fromImage=homeassistant%2Fraspberrypi4-homeassistant: Internal Server Error (“Get “https://registry-1.docker.io/v2/”: context deadline exceeded”).
21-02-28 17:25:02 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-28 17:25:32 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-homeassistant:landingpage to homeassistant/raspberrypi4-homeassistant:2021.2.3
21-02-28 17:25:32 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-homeassistant with tag 2021.2.3.
21-02-28 17:25:47 ERROR (SyncWorker_1) [supervisor.docker.interface] Can’t install homeassistant/raspberrypi4-homeassistant:2021.2.3 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2021.2.3&fromImage=homeassistant%2Fraspberrypi4-homeassistant: Internal Server Error (“Get “https://registry-1.docker.io/v2/”: context deadline exceeded (Client.Timeout exceeded while awaiting headers)”).
21-02-28 17:25:47 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-28 17:26:17 INFO (SyncWorker_4) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-homeassistant:landingpage to homeassistant/raspberrypi4-homeassistant:2021.2.3
21-02-28 17:26:17 INFO (SyncWorker_4) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-homeassistant with tag 2021.2.3.
21-02-28 17:26:32 ERROR (SyncWorker_4) [supervisor.docker.interface] Can’t install homeassistant/raspberrypi4-homeassistant:2021.2.3 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2021.2.3&fromImage=homeassistant%2Fraspberrypi4-homeassistant: Internal Server Error (“Get “https://registry-1.docker.io/v2/”: context deadline exceeded”).
21-02-28 17:26:32 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
I’ve been stuck for 2 days and bought numerous new cards tried 2 different pis and cables and routers and card readers and 32 or 64bit … i did not go down the old version hole though…because when i searched my issue i found you…i took your advice… .i found a way to add them with a usb stick but only after it starts not during this bootloop I’m also stuck in. .i made an account just to ask you how!.. so Nickwaldvogel will you be my angel?
