I did set up my Eagle 200 device in HomeAssistent and the
device shows up on the HomeAssistant website but the readings are empty.
The log indicates no Errors and the readings are just ‘None’. I can see the correct readings if I use the Eagle Website. Also, I rebooted the Eagle device and the Rasberry Pie. No luck.
I set up my Eagle 200 in the configuration.xaml
like this:
- platform: rainforest_eagle
ip_address: 192.168.86.XX
cloud_id: 0049XX
install_code: 2f39b237aa928XXX
The Debug output is this:
'summation_received': None, 'summation_total': None}
2020-01-07 17:44:38 DEBUG (SyncWorker_9) [homeassistant.components.rainforest_eagle.sensor] Updating: summation_total - None
2020-01-07 17:44:38 DEBUG (SyncWorker_11) [homeassistant.components.rainforest_eagle.sensor] Updating: summation_received - None
2020-01-07 17:44:38 DEBUG (SyncWorker_8) [homeassistant.components.rainforest_eagle.sensor] Updating: summation_delivered - None
2020-01-07 17:44:38 DEBUG (SyncWorker_7) [homeassistant.components.rainforest_eagle.sensor] Updating: instantanous_demand - None
2020-01-07 17:45:09 DEBUG (SyncWorker_4) [homeassistant.components.rainforest_eagle.sensor] API data: {'instantanous_demand': None, 'summation_delivered': None, 'summation_received': None, 'summation_total': None}
2020-01-07 17:45:09 DEBUG (SyncWorker_4) [homeassistant.components.rainforest_eagle.sensor] Updating: instantanous_demand - None
2020-01-07 17:45:09 DEBUG (SyncWorker_5) [homeassistant.components.rainforest_eagle.sensor] Updating: summation_received - None
2020-01-07 17:45:09 DEBUG (SyncWorker_0) [homeassistant.components.rainforest_eagle.sensor] Updating: summation_delivered - None
2020-01-07 17:45:09 DEBUG (SyncWorker_15) [homeassistant.components.rainforest_eagle.sensor] Updating: summation_total - None
2020-01-07 17:45:40 DEBUG (SyncWorker_3) [homeassistant.components.rainforest_eagle.sensor] API data: {'instantanous_demand': None, 'summation_delivered': None, 'summation_received': None, 'summation_total': None}
2020-01-07 17:45:40 DEBUG (SyncWorker_3) [homeassistant.components.rainforest_eagle.sensor] Updating: instantanous_demand - None
2020-01-07 17:45:40 DEBUG (SyncWorker_14) [homeassistant.components.rainforest_eagle.sensor] Updating: summation_delivered - None
2020-01-07 17:45:40 DEBUG (SyncWorker_13) [homeassistant.components.rainforest_eagle.sensor] Updating: summation_total - None
2020-01-07 17:45:40 DEBUG (SyncWorker_1) [homeassistant.components.rainforest_eagle.sensor] Updating: summation_received - None
2020-01-07 17:46:11 DEBUG (SyncWorker_5) [homeassistant.components.rainforest_eagle.sensor] API data: {'instantanous_demand': None, 'summation_delivered': None,
