My insteon hub is powerlinc USB modem 2413U. I am trying to link the subject switch. I had two new unused ones on original box. I had pretty much given up on insteon but hey I have them , they are new and I don’t think there ia z wave equivalent When I use the following instructions
Make On/Off Outdoor Module a Responder
- Press and hold controller set button until it beeps
Controller LED will start blinking
You will have four minutes to complete the next steps before linking mode times out- Use On/Off Module set button to adjust load to desired state (on or off)
- Press and hold On/Off Outdoor Module set button until it double-beeps
Controller will double-beep and its LED will stop blinking- Test link by tapping controller button on and off
Lamp connected to On/Off Outdoor Module will respond appropriately
I never get the double beep. I can turnteh light one or off with the set switch but when on the set switch only flashed green
I am using
Code 2024.11.1
Supervisor 2014.1.2
Operator System 13.2
Frontend 20241106.2
I am operating on. a Linux Virtual Machine Hosted on Mac OSX
Any comments (even I am screwed) would be appreciated
