Need serious help here. I can not load any Home Assistant Community Addons. I’ve searched thru the forum but I didn’t see solutions to my situation. I can update Core/Supervisor/Host, no problem. I can add/update Official Addons no problem. I can even update Community add-ons previously loaded, like Node-Red, Studio Server, SSH Terminal, just can’t add any new community add-ons. I get
22-01-18 21:14:33 ERROR (MainThread) [supervisor.store.git] Can’t clone https://addons.community repository: Cmd(‘git’) failed due to: exit code(128)
- cmdline: git clone -v --recursive --depth=1 --shallow-submodules https://addons.community /data/addons/git/942cda15*
- stderr: ‘Cloning into ‘/data/addons/git/942cda15’…*
fatal: repository ‘https://addons.community/’ not found’
I have 2 instances of HA running on 2 separate machines, both on the same network. they are both suffering from the same problem. I have another instance running at a different location that does not have the problem. Most everything I read suggests its a DNS problem. I have added/subtracted a bunch of DNS’s 8.8.8.8, 8.8.4.4, 1.1.1.1 etc but nothing helps. It obviously worked previously but I haven’t needed to load an Add-on for a while so I don’t know when things changed. I’m stuck. Any advise would be much a appreciated, thanks
