I was logged in and had no issues using the the applications. I logged out and have not been able to log back in. I have been through all the trouble shooting steps with no luck. I have even factory reset my phone. I am using a Samsung s22 on android 12.
It turns out the I was able to log in, however the Finish button was not visible. I was not able to complete the onboarding.
While collecting logs I connect to the phone with Samsung’s DeX windows application and went through the on boarding again. The Finish button was visible.
Here is part of the logcat from when the Enable Location Tracking switch was toggled.
2022-09-29 15:38:34.511 2195-2341 WindowManager pid-2195 I Reparenting to original parent: Surface(name=ActivityRecord{c113774 u0 io.homeassistant.companion.android/.onboarding.OnboardingActivity t547})/@0xadb9c91, destroy=true, surface=Surface(name=9b2752d io.homeassistant.companion.android/io.homeassistant.companion.android.onboarding.OnboardingActivity)/@0x31604f
2022-09-29 15:38:34.511 2195-2341 WindowManager pid-2195 E win=Window{9b2752d u0 io.homeassistant.companion.android/io.homeassistant.companion.android.onboarding.OnboardingActivity EXITING} destroySurfaces: appStopped=false win.mWindowRemovalAllowed=true win.mRemoveOnExit=true win.mViewVisibility=0 caller=com.android.server.wm.ActivityRecord.destroySurfaces:5867 com.android.server.wm.ActivityRecord.destroySurfaces:5848 com.android.server.wm.WindowState.onExitAnimationDone:5989 com.android.server.wm.WindowStateAnimator.onAnimationFinished:242 com.android.server.wm.WindowState.onAnimationFinished:6242 com.android.server.wm.WindowContainer$$ExternalSyntheticLambda0.onAnimationFinished:2 com.android.server.wm.SurfaceAnimator.lambda$getFinishedCallback$0$SurfaceAnimator:113
2022-09-29 15:38:34.511 2195-2341 WindowManager pid-2195 I Destroying surface Surface(name=io.homeassistant.companion.android/io.homeassistant.companion.android.onboarding.OnboardingActivity$_30847)/@0xcbd3e1c called by com.android.server.wm.WindowStateAnimator.destroySurface:987 com.android.server.wm.WindowStateAnimator.destroySurfaceLocked:518 com.android.server.wm.WindowState.destroySurfaceUnchecked:4246 com.android.server.wm.WindowState.destroySurface:4220 com.android.server.wm.ActivityRecord.destroySurfaces:5867 com.android.server.wm.ActivityRecord.destroySurfaces:5848 com.android.server.wm.WindowState.onExitAnimationDone:5989 com.android.server.wm.WindowStateAnimator.onAnimationFinished:242
