Hi everyone, first a big thank because im super new in Home Assistant but with all the information in this forum i was able to make a lot of new things.
Here i want to describe a problem i have to make it everything work on ZHA or Zigbee2MQTT:
I was able to add Zigbee Motion Sensor (ZG-204Z) https://www.aliexpress.com/item/1005004857629157.html the problem here is ZHA detect as Smoke Sensor and i have no way to make it work correctly, in real this model is motion detector and include lux sensor
instead in Z2M is work perfect and full able to access motion sensor and lux sensor, but my problem is in Z2M i can not make all devices work perfect, per example Aqara Cube (MFKZQ01LM)
Hi!
I also have a ZG-204ZL, and I tested its quirk with my new ZG-204Z and got mixed results. I got the occupancy sensor working, which is a huge plus, but still shows a smoke sensor and the battery indicator is showing a 0 % alert.
To accomplish this, I modified the identification part, to the proper identificator (_TZE200_bh3n6gk8), and deleted the illuminance sensor stuff from everywhere. Also changed some class names but this I think had no effect.
warning 2025-07-23 17:38:57z2m: Device '' with Zigbee model 'ZG-204Z' and manufacturer name 'HOBEIAN' is NOT supported, please follow https://www.zigbee2mqtt.io/advanced/support-new-devices/01_support_new_devices.html
I could pair it with ZHA, but it only shows Lux and Presence - no options for PIR and/or Radar, no options for detection range. Anyone got this thing working correctly?
