Can not reinstall new Home Assistant Green
I have got a new Home Assistant Green a few days ago. During my first attempts to install different Add-Ons the system could not boot. I have tried to reset it. But it didn’t work. I have connected a display to HDMI. dmesg produced some errors, that the system could not read 1st and 2nd block in my mmcblk (eMMC) device.
I decided to download the new image, put it on the micro-SD card and re-install the OS. Apparently it should work. But it runs for around 1 hour without any changes. The last messages were:
haos-flash[326]: Getting latest Home Assistant OS version from channel stable...
haos-flash[326]: Installing Home Assistant OS 16.3 to mmcblk0.
I have downloaded this file from GitHub: green-installer-20240410.img. It’s only around 73MB. Is it the correct file?
I am just nor sure, if my eMMC is healthy or maybe corrupt.
Ctrl+Alt+F2 on the keyboard does not work to use dimes or top for the progress.
After a 1-2 hours I have got these messages:
haos-flash[332]: curl: (18) transfer closed with 294917064 bytes remaining to read
Alternative GPT is invalid, using primary GPT.
mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
haos-flash[334]: 0+11449 records in
haos-flash[334]: 0+11449 records out
haos-flash[326]: Error doing Home Assistant OS installation.
The issue the micro SD card. Today I have bought a new one and used it for the installation. The same image was written to the new card. Home Assistant Green took only some minutes to flush the internal eMMC.
Hi Andrej2,
I need to re-image the HA Green as well, but cannot find the image on Github, can you guide me a bit in the right direction?
Thanks,
Rene
I'll jump in because that user hasn't been on the forums since January.
Start here https://support.nabucasa.com/hc/en-us/articles/25161225495837-Resetting-Home-Assistant-Green
If that doesn't work, do it via the SD card method instead https://support.nabucasa.com/hc/en-us/articles/25162566451485-Resetting-Home-Assistant-Green-using-an-SD-card
The file you are looking for is at the top of this page Releases · NabuCasa/buildroot-installer · GitHub
