Can not remove integrations installed via HACS
Edit: after trying to remove it from hacs it seemed I could remove it from integrations too :thinking:
Bit backwards but seems to work
I am trying to remove some integrations I installed via HACS. And I cant get it to work.
I know that via HACS I can click the 3 dots and remove it via HACS but I get “integration is configured” and that I need to remove the integrations in the hass integrations interface.
When I do this though push delete etc NOTHING happens.
How do I get rid of the integration?
Thank you all in advance
/Thrawn
Disable the integration, restart HA, remove/delete the integration … some times you can’t remove/delete, because it’s “loaded” and tight up in “processes”
Thank you so much for your help!
I did that several times without luck
But it seems I could remove from hacs THEN I could remove from integrations :thinking:
So yes seems to work now
