Hi Everyone
I have my Pi3 setup with Hassbian and deconz + duckdns and letscrypt. It has been running flawless for about 2½ months now.
But time has come to renew the letsencrypt certificate and I cannot get it to work .
The command I am trying to execute is the following:
$ ./certbot-auto renew --quiet --no-self-upgrade --standalone --preferred-challenges http-01
I am not at the computer right now but it said something a long the lines of “could not bind on port 80”.
When I set it up initiall I used this guide: https://www.home-assistant.io/docs/ecosystem/certificates/lets_encrypt/
lolouk44
(lolouk44)
May 22, 2018, 9:16am
2
Do you have Apache running? If so you’ll have to stop it before you can renew.
I have stopped the homeassistant service if that is what you mean? I dont believe I have installed apache.
lolouk44
(lolouk44)
May 22, 2018, 9:32am
4
no, I mean apache. Home assistant runs on port 8123. Do you have a web server on your machine that would run on port 80?
What happens when you type the IP address of your server in a browser?
Ah I think I know what you mean, I have deconz runnning and when I enter the server address I get to the “Wireless light control system”. So im guessing that is what I need to stop before renewing?
Great that makes sense. I will give it a go tonight and report back.
It worked
For others coming here, what I did was:
Login with user “pi”
Stop the deconz service with
sudo systemctl stop deconz
Navigate to certbot folder with
cd certbot
Run update script with
sudo ./certbot-auto renew --no-self-upgrade --standalone --preferred-challenges http-01
