Can not restart HA
I tried to change an iocn of a binary sensor. (I saw a post which explained I could used the customizations menu). I changed the icon, it worked but I got a message that I should add in my configuration.yaml the
homeassistant:
  customize: !include customize.yaml
I added it, but it won’t let me restart.
in Configuration validation i get the
component error: customize - Integration 'customize' not found.
and if I try to restart in the notification tells me to check my config… and it won’t restart…
edit: I removed the customization (changed back the icon to door from garage) with the same result
What I can do?
Can you please show the relevant part of your configuration.yaml file and the customize.yaml file as well?
Are you sure that this part
is under the homeassistant: section and intended as in the example you posted?
Because the error looks like you have it unintended and therefore it looks for a integration called customize, which doesn’t exist.
That was the problem. I didn’t used the homeassistant:
Now I restart it and it is working fine.
You gave me 2/2 fast solutions today.
Thanks!
