Can not save changes to homekit bridges. Only Accessory
Edit:
I just figured out that the one working is running as accessory as soon as I try to change it to bridge (with the same device) it will not working and tries to save for ages with the same unknown error in the end.
Anyone have any ideas?
Hi
I am running 4 different homeassistant homekit bridges (to make it easier to find the devices I need)
All is running on latest version of home assistant os.
All of a sudden I can’t change any of my bridges anymore, If I add or remove a new device it tries to run for some time after I push submit then says unknown error.
Funny thing is I can add a new bridge and that works fine.
Now I it seems I can fix this by re adding all my bridges, but before doing that I would like to avoid this happening again.
Does anyone know what the issue could be?
I have a “sandbox” home assistant running in docker and it works fine there.
Thank you all in advance
/Thrawn
