Can not seem to update Hassio?
I can not update to the latest release, What could be wrong?
19-12-22 15:04:19 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.103.3
19-12-22 15:04:19 INFO (SyncWorker_10) [hassio.docker.interface] Update image homeassistant/qemux86-64-homeassistant:0.101.2 to homeassistant/qemux86-64-homeassistant:0.103.3
19-12-22 15:04:19 INFO (SyncWorker_10) [hassio.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.103.3.
19-12-22 15:05:10 ERROR (SyncWorker_10) [hassio.docker.interface] Can't install homeassistant/qemux86-64-homeassistant:0.103.3 -> 404 Client Error: Not Found ("no such image: homeassistant/qemux86-64-homeassistant:0.103.3: No such image: homeassistant/qemux86-64-homeassistant:0.103.3").
19-12-22 15:05:10 WARNING (MainThread) [hassio.homeassistant] Update Home Assistant image fails
19-12-22 15:07:43 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
Do you have api_password: in your configuration?
No I don’t have it in my configuration. Would it be some where else?
Hi Dave,
can you check if there is enough free space on your local device?
If you use Hass.io (as it seems to be), maybe update your Configurator add-on. I wasn’t able to to update the OS ( to HassOS 3.7) with Configurator version 4.1 , but can’t verify if that was the reason.
Ya there is enough free space. That was the first thing I checked. In the mean time I’m setting up a second Hassio and transferring my config over now. The second setup does updates with no problems.
