Can not select advanced mode
hi
im new with home assistant
Im running on pi 3. and used the image from startup.
when I first run and setup I could and did switched the advanced mode but now it is greyed out??
also the ssh adon I can not find.
thanks
As long as you have not set advanced mode, you can’t install ssh. Check if you are an ‘administrator’
yes I know that.
as I wrote I did could switch it before.
and the ssh and some other add-ons are not visible.
I´m having the same problem and i can´t solve it… Anyone ?
has anyone solved this problem ?
What if you create a new (administrator) user, and then log in as the new user. Can you set advanced mode then ?
I am bringing up again this post as I have the same problem. No advance mode is selectable, the toggle is greyed out.
Anyone can help?
