I have added some “covers” - Brunt blind engines - to HA and I can control them through the front page / Lovelace, but I am unable to create an Automation for them.
When I select the dropdown list under “Actions” in the Automations page none of the 4 blind motors appear.
Why might a device appear under Develop Tools / States, but not within Configuration / Devices or / Entities?
Not all entities have a device, but for some reason the automation editor defaults to device triggers and actions.
Change the first drop down in the action block to ‘call service’, then set the service to cover.open (or close) and then set the entity_id to that of your blinds.
Many thanks @anon43302295 - very helpful. But could I be a nuisance and ask you to expand on that a bit? I have started to create an Automation as follows …
Name: Sitting Room Curtains (Open, SR)
Triggers: Sun / Sunrise
Conditions: n/a
Actions: Action Type: Call Service
I tried putting ``cover.stting_room_n.open` in the Service subsection, but that caused an error
Message malformed: Service cover.stting_room_n.open does not match format <domain>.<name> for dictionary value @ data['action'][0]['service']
If I just put cover.open no error comes up, but where would I define which blind I want to action?
I had to make one small change to what you said @anon43302295 (but that is understandable if you don’t have any covers), in that using cover.open didn’t bring up the next line where I could then type cover.sitting_room_n, but if I chose cover.close_cover instead it did.
Very happy now - hours of wasted time yesterday sorted in 15 minutes today!
