Can not start Broadlink component after installing HA 0.62.1
Hi geeks,
I’ve installed HA 0.62.1 successfully via Termux. By the way, the Broadlink component did not work as usual.
I’ve already checked and updated the latest verison of Python & pycrypto lib. The configuration.yaml file is also correct.
Has anyone got the similar situation like this?
Thank you.
Here is brief of log:
2018-01-31 19:00:49 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=14 from 2018-01-31 18:43:00.681727)
2018-01-31 19:00:52 ERROR (MainThread) [homeassistant.components.switch] Error while setting up platform broadlink
  File "/data/com.termux/files/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_component.py", line 189, in _async_setup_platform
    SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
  File "/data/com.termux/files/usr/lib/python3.6/asyncio/tasks.py", line 358, in wait_for
    return fut.result()
  File "/data/com.termux/files/usr/lib/python3.6/asyncio/futures.py", line 243, in result
    raise self._exception
  File "/data/com.termux/files/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/data/com.termux/files/usr/lib/python3.6/site-packages/homeassistant/components/switch/broadlink.py", line 176, in setup_platform
    broadlink_device.auth()
  File "/data/com.termux/files/home/.homeassistant/deps/lib/python3.6/site-packages/broadlink/__init__.py", line 203, in auth
    response = self.send_packet(0x65, payload)
  File "/data/com.termux/files/home/.homeassistant/deps/lib/python3.6/site-packages/broadlink/__init__.py", line 258, in send_packet
    payload = self.encrypt(payload)
  File "/data/com.termux/files/home/.homeassistant/deps/lib/python3.6/site-packages/broadlink/__init__.py", line 162, in encrypt_pyaes
    return "".join([aes.encrypt(bytes(payload[i:i+16])) for i in range(0, len(payload), 16)])
TypeError: sequence item 0: expected str instance, bytes found
