Hello all,
i hope you are fine .
I do have an issue, that i am not able to update anymore and the log file is nor helping me here.
I was hoping with the update to solve another issue with the presence detection but first the update.
Currently im running on 0.83.3
Hostname hassio
System HassOS 1.10
Deployment production
Hass.io supervisor
Version 142
Latest version 142
If i press update via the webinterface, nothing happens.
Also no error message in the logs.
(A restart ist also not working via the web interface)
So i tried it via SSH (installed the ADD-ON first.) It provides me with an unknonw error, i should see the logs.
But there i am not able to see any reason why it was not working
Here is the logs:
core-ssh:~# hassio homeassistant update
ERROR
Unknown Error, see logs
core-ssh:~# hassio homeassistant logs
Error decoding json invalid character '-' after top-level value: 2019-01-20 21:53:39 INFO (SyncWorker_5) [homeassistant.components.tado] Querying mytado.com for zone 1 Wohnzimmer
2019-01-20 21:53:39 INFO (SyncWorker_5) [homeassistant.components.tado] Querying mytado.com for zone 2 Badezimmer
2019-01-20 21:53:39 INFO (SyncWorker_5) [homeassistant.components.tado] Querying mytado.com for device XXXX xxx
2019-01-20 21:53:46 INFO (MainThread) [homeassistant.components.http.view] Serving / to 192.168.1.158 (auth: False)
2019-01-20 21:53:46 INFO (MainThread) [homeassistant.components.http.view] Serving /api/websocket to 192.168.1.158 (auth: False)
2019-01-20 21:54:13 INFO (SyncWorker_7) [homeassistant.components.tado] Querying mytado.com for zone 1 Wohnzimmer
2019-01-20 21:54:13 INFO (SyncWorker_7) [homeassistant.components.tado] Querying mytado.com for zone 2 Badezimmer
2019-01-20 21:54:13 INFO (SyncWorker_7) [homeassistant.components.tado] Querying mytado.com for device XXXX XXXX
2019-01-20 21:54:30 WARNING (MainThread) [homeassistant.components.sensor] Updating hue sensor took longer than the scheduled update interval 0:00:00.100000
2019-01-20 21:54:40 INFO (SyncWorker_13) [homeassistant.components.tado] Querying mytado.com for zone 1 Wohnzimmer
2019-01-20 21:54:40 INFO (SyncWorker_13) [homeassistant.components.tado] Querying mytado.com for zone 2 Badezimmer
2019-01-20 21:54:40 INFO (SyncWorker_13) [homeassistant.components.tado] Querying mytado.com for device 101577 XXXXX
2019-01-20 21:55:15 INFO (SyncWorker_18) [homeassistant.components.tado] Querying mytado.com for zone 1 Wohnzimmer
2019-01-20 21:55:15 INFO (SyncWorker_18) [homeassistant.components.tado] Querying mytado.com for zone 2 Badezimmer
2019-01-20 21:55:15 INFO (SyncWorker_18) [homeassistant.components.tado] Querying mytado.com for device 101577 XXXXX
2019-01-20 21:55:41 INFO (SyncWorker_4) [homeassistant.components.tado] Querying mytado.com for zone 1 Wohnzimmer
2019-01-20 21:55:41 INFO (SyncWorker_4) [homeassistant.components.tado] Querying mytado.com for zone 2 Badezimmer
2019-01-20 21:55:41 INFO (SyncWorker_4) [homeassistant.components.tado] Querying mytado.com for device 101577 XXXX
2019-01-20 21:55:46 INFO (MainThread) [homeassistant.components.http.view] Serving / to 192.168.1.158 (auth: False)
2019-01-20 21:55:46 INFO (MainThread) [homeassistant.components.http.view] Serving /api/websocket to 192.168.1.158 (auth: False)
2019-01-20 21:56:17 INFO (SyncWorker_0) [homeassistant.components.tado] Querying mytado.com for zone 1 Wohnzimmer
2019-01-20 21:56:17 INFO (SyncWorker_0) [homeassistant.components.tado] Querying mytado.com for zone 2 Badezimmer
2019-01-20 21:56:17 INFO (SyncWorker_0) [homeassistant.components.tado] Querying mytado.com for device 101577 XXXX
2019-01-20 21:56:28 INFO (MainThread) [homeassistant.components.http.view] Serving /api/error/all to 192.168.1.34 (auth: True)
2019-01-20 21:56:40 INFO (MainThread) [homeassistant.components.http.view] Serving /api/hassio/app/entrypoint.js to 192.168.1.34 (auth: False)
2019-01-20 21:56:40 INFO (MainThread) [homeassistant.components.http.view] Serving /api/hassio/app/chunk.f32f3c841cc3e1d081f7.js to 192.168.1.34 (auth: False)
2019-01-20 21:56:41 INFO (MainThread) [homeassistant.components.http.view] Serving /api/hassio/app/chunk.8c049a124b9397e54c16.js to 192.168.1.34 (auth: False)
2019-01-20 21:56:41 INFO (MainThread) [homeassistant.components.http.view] Serving /api/hassio/app/chunk.c1ac97370d72bce0a835.js to 192.168.1.34 (auth: False)
2019-01-20 21:56:41 INFO (MainThread) [homeassistant.components.http.view] Serving /api/hassio/app/chunk.d0eb7b86b775838caf5e.js to 192.168.1.34 (auth: False)
2019-01-20 21:56:41 INFO (MainThread) [homeassistant.components.http.view] Serving /api/hassio/supervisor/info to 192.168.1.34 (auth: True)
2019-01-20 21:56:41 INFO (MainThread) [homeassistant.components.http.view] Serving /api/hassio/host/info to 192.168.1.34 (auth: True)
2019-01-20 21:56:41 INFO (MainThread) [homeassistant.components.http.view] Serving /api/hassio/homeassistant/info to 192.168.1.34 (auth: True)
2019-01-20 21:56:41 INFO (MainThread) [homeassistant.components.http.view] Serving /api/hassio/app/chunk.0853908528652fbc5d4f.js to 192.168.1.34 (auth: False)
2019-01-20 21:56:41 INFO (MainThread) [homeassistant.components.http.view] Serving /api/hassio/app/chunk.9e3883f96f68b3ce89f5.js to 192.168.1.34 (auth: False)
2019-01-20 21:56:42 INFO (SyncWorker_7) [homeassistant.components.tado] Querying mytado.com for zone 1 Wohnzimmer
2019-01-20 21:56:42 INFO (SyncWorker_7) [homeassistant.components.tado] Querying mytado.com for zone 2 Badezimmer
2019-01-20 21:56:42 INFO (SyncWorker_7) [homeassistant.components.tado] Querying mytado.com for device 101577 XXXX
2019-01-20 21:56:44 INFO (MainThread) [homeassistant.components.http.view] Serving /api/error/all to 192.168.1.34 (auth: True)
2019-01-20 21:56:51 INFO (MainThread) [homeassistant.components.http.view] Serving /api/events to 192.168.1.34 (auth: True)
2019-01-20 21:56:52 INFO (MainThread) [homeassistant.components.http.view] Serving /api/hassio/app/entrypoint.js to 192.168.1.34 (auth: False)
2019-01-20 21:56:52 INFO (MainThread) [homeassistant.components.http.view] Serving /api/hassio/app/chunk.f32f3c841cc3e1d081f7.js to 192.168.1.34 (auth: False)
2019-01-20 21:56:52 INFO (MainThread) [homeassistant.components.http.view] Serving /api/hassio/app/chunk.8c049a124b9397e54c16.js to 192.168.1.34 (auth: False)
2019-01-20 21:56:52 INFO (MainThread) [homeassistant.components.http.view] Serving /api/hassio/app/chunk.c1ac97370d72bce0a835.js to 192.168.1.34 (auth: False)
2019-01-20 21:56:52 INFO (MainThread) [homeassistant.components.http.view] Serving /api/hassio/app/chunk.d0eb7b86b775838caf5e.js to 192.168.1.34 (auth: False)
2019-01-20 21:56:53 INFO (MainThread) [homeassistant.components.http.view] Serving /api/hassio/supervisor/info to 192.168.1.34 (auth: True)
2019-01-20 21:56:53 INFO (MainThread) [homeassistant.components.http.view] Serving /api/hassio/host/info to 192.168.1.34 (auth: True)
2019-01-20 21:56:53 INFO (MainThread) [homeassistant.components.http.view] Serving /api/hassio/homeassistant/info to 192.168.1.34 (auth: True)
2019-01-20 21:56:53 INFO (MainThread) [homeassistant.components.http.view] Serving /api/hassio/app/chunk.0853908528652fbc5d4f.js to 192.168.1.34 (auth: False)
2019-01-20 21:56:53 INFO (MainThread) [homeassistant.components.http.view] Serving /api/hassio/app/chunk.9e3883f96f68b3ce89f5.js to 192.168.1.34 (auth: False)
2019-01-20 21:56:54 INFO (MainThread) [homeassistant.components.http.view] Serving /api/hassio/hassos/info to 192.168.1.34 (auth: True)
2019-01-20 21:56:54 INFO (MainThread) [homeassistant.components.http.view] Serving /api/hassio/supervisor/logs to 192.168.1.34 (auth: True)
2019-01-20 21:57:04 INFO (MainThread) [hole] Response from *hole: 200
2019-01-20 21:57:19 INFO (SyncWorker_6) [homeassistant.components.tado] Querying mytado.com for zone 1 Wohnzimmer
2019-01-20 21:57:19 INFO (SyncWorker_6) [homeassistant.components.tado] Querying mytado.com for zone 2 Badezimmer
2019-01-20 21:57:20 INFO (SyncWorker_6) [homeassistant.components.tado] Querying mytado.com for device 101577 XXXX
2019-01-20 21:57:26 INFO (MainThread) [homeassistant.components.http.view] Serving /api/hassio/supervisor/logs to 192.168.1.34 (auth: True)
2019-01-20 21:57:43 INFO (SyncWorker_16) [homeassistant.components.tado] Querying mytado.com for zone 1 Wohnzimmer
2019-01-20 21:57:43 INFO (SyncWorker_16) [homeassistant.components.tado] Querying mytado.com for zone 2 Badezimmer
2019-01-20 21:57:44 INFO (SyncWorker_16) [homeassistant.components.tado] Querying mytado.com for device 101577 XXXX
2019-01-20 21:57:46 INFO (MainThread) [homeassistant.components.http.view] Serving / to 192.168.1.158 (auth: False)
2019-01-20 21:57:47 INFO (MainThread) [homeassistant.components.http.view] Serving /api/websocket to 192.168.1.158 (auth: False)
2019-01-20 21:57:47 WARNING (MainThread) [homeassistant.components.sensor] Updating hue sensor took longer than the scheduled update interval 0:00:00.100000
2019-01-20 21:57:48 INFO (MainThread) [homeassistant.components.http.view] Serving /api/ to 172.30.32.2 (auth: True)
2019-01-20 21:58:21 INFO (SyncWorker_7) [homeassistant.components.tado] Querying mytado.com for zone 1 Wohnzimmer
2019-01-20 21:58:21 INFO (SyncWorker_7) [homeassistant.components.tado] Querying mytado.com for zone 2 Badezimmer
2019-01-20 21:58:22 INFO (SyncWorker_7) [homeassistant.components.tado] Querying mytado.com for device 101577 XXXX
2019-01-20 21:58:37 WARNING (MainThread) [homeassistant.components.sensor] Updating hue sensor took longer than the scheduled update interval 0:00:00.100000
2019-01-20 21:58:44 INFO (SyncWorker_5) [homeassistant.components.tado] Querying mytado.com for zone 1 Wohnzimmer
2019-01-20 21:58:44 INFO (SyncWorker_5) [homeassistant.components.tado] Querying mytado.com for zone 2 Badezimmer
2019-01-20 21:58:44 INFO (SyncWorker_5) [homeassistant.components.tado] Querying mytado.com for device 101577 XXXX
2019-01-20 21:59:23 INFO (SyncWorker_13) [homeassistant.components.tado] Querying mytado.com for zone 1 Wohnzimmer
2019-01-20 21:59:23 INFO (SyncWorker_13) [homeassistant.components.tado] Querying mytado.com for zone 2 Badezimmer
2019-01-20 21:59:24 INFO (SyncWorker_13) [homeassistant.components.tado] Querying mytado.com for device 101577 XXXX
core-ssh:~#
SO i am a little lost here, i am guessing the issue is somewhere there:
2019-01-20 21:56:42 INFO (SyncWorker_7) [homeassistant.components.tado] Querying mytado.com for device 101577 Rada
Any Ideas here ?
Thanks for any help
