Hello, in Homekit only allows to change source and tell if its on.
erase the homekit integration for the lg tv
i got it to work using this code i entered in the configuration.yaml
webostv:
host: your tv ip address
turn_on_action:
service: persistent_notification.create
message: "Turn on action"
customize:
sources:
- livetv
- hdmi2
- hdmi1
- airplay
- hulu
- vudu
- youtube
- disney
- photo
- netflix
media_player:
notify:
you have to go to the tv settings/network and activate lg conected apps
restart server and a notification will pop up that says configure lg tv, press there and a menu will
pop up and say start pairing tv(or something like it)
press it and go to the tv and get the code on screen and insert it in the menu when it asks for code in HA
create a media card and a entity card
in the media card will show the opened app of the tv
you will be able to turn off, change volumes, channels, sources(still figuring out how to call hdmi 1,3)
in sources you can add other apps you use. only added what i use.
if it doesnt find the tv in the pairing menu, check that you used the correct ip address for your tv in your network.
hope it helps!
