My question is has anybody added scripts and imported them into HomeKit? Mine show up ok and work but unlike in Homebridge they stay on like a Boolean Switch. I liked the fact that the script would immediately turn off after activating the script via my HomePod. This made it very easy to use my harmony hub and write scripts to change the channels, turn on the tv, adjusting the volume. Now because they stay on it makes the process more difficult. Does anybody know if there’s a line I can add in my script to turn off after activating it?
Did it work (a script stopping itself)?
I have had cause to want to do this but always ended up going down a route I knew would work because I am put off experimenting by the time it takes my HA to restart. (hassio on Pi)
I’m using packages so unfortunately nothing can be reloaded.
Packages are brilliant but flawed, if you’re not using them I suggest you look into it. The flaw is that they do not allow you to reload scripts/automations etc. you have to restart.
Can you please provide an example,of what you did? I’m trying to create a momentary switch that I can call from Siri. You turn it on, and then it does something and then turns itself off again.
I added the code, but some not working. If i call i script from homekit, it keeps activated. When using homebridge the script turns off again automatically. This behavior is what i want.
