I am suffering from severe issues in my Zigbee network. To debug/understand the issues a bit better, I would like to make sure I understand which routers a device takes. But everything seems completely non reproducible, random and doesn’t make sense forever.
Just as an example, take the debive blinds_dining_1 below. This device goes offline all the time, totally randomly and I swear it has great signal range.
I use zigbee2mqtt with the Sonoff Zigbee dongle. Right now, it shows LQI=116 in the devices list
How can I verify which routers it takes?
Below shows a screenshot of my mesh. But no number here makes 116. I would assume that the endpoint device LQI value should match the worst case link value across a chosen (optimal) path. If we take for example the path from the first plug to the coordinator, then LQI_tot = MIN{94,117}=94.
Now I see 117 is close to 116 and even if this WOULD make sense, this is just an example. I see all the time scenarios in which the end device LQI value is literally totally different from everything else in the mesh.
