stevemann
(Stephen Mann (YAML-challenged))
September 30, 2023, 10:42pm
1
Can someone help me figure out why I can’t run a script from a card?
Here is my card code:
type: custom:button-card
name: Play File 1
tap_action:
action: call-service
service: script.turn_on
service_data:
entity_id: script.play_mp3_file
entity_id:
- script.play_mp3_file
file: 1
No errors, but the file is not playing.
From developer tools, I can play file 1:
service: script.play_mp3_file
file: 1
Here is the code for the script:
alias: play_mp3_file
sequence:
- service: esphome.dfplayer_dfplayer_play
file: "{{ file }}"
mode: single
icon: mdi:music
Any tips would be appreciated.
paddy0174
(Patrick)
September 30, 2023, 11:14pm
2
I’m not entirely sure, but service_data
was deprecated I think. Try without, you shouldn’t need it anyway.
tap_action:
entity_id:
file: 1
If i remember right, you’re overwriting data
with service_data
or vice versa.
msp1974
(Mark P)
September 30, 2023, 11:34pm
3
You should just copy what you did in developer tools. Ie.
name: Play File 1
tap_action:
file: 1
stevemann
October 1, 2023, 1:03am
4
Thanks for the tip, but
name: Play File 1
tap_action:
entity_id:
file: 1
gives this error:
“Failed to call service/script.turn_on. must contain one of entity_id, device_id or area_id.”
stevemann
October 1, 2023, 1:08am
5
I am sure that I tried this, but
name: Play File 1
tap_action:
file: 1
gives this error:
Failed to call service/script.play_mp3_file. expected int for dictionary value @ data[“file”]
The last time I looked, 1 was an int?
That format is working for me with a script that requires an int
, post the trace of the script.
stevemann
October 1, 2023, 5:00am
7
Here are the Step Details:
Result:
params:
domain: esphome
service: dfplayer_dfplayer_play
service_data:
file: ''
target: {}
running_script: false
Interesting that file: is null?
I have another test script that does not take an argument- the file number is hard coded:
alias: play_mp3_file_4
sequence:
file: 4
mode: single
icon: mdi:music-note-eighth
This one works and the trace shows file: 4
It’s only when trying to pass the file number as an argument that it fails.
Honestly this is the first script that I have written that takes a parameter.
Here, again for reference, is the failing script:
sequence:
file: "{{ file }}"
mode: single
icon: mdi:music
I don’t see anything glaringly wrong… I would try it with defined variable fields and force the template to output an integer. It’s probably just coincidence, but I’ve had a few instances where a variable would not pass correctly until I set up the fields block.
fields:
file:
description: "The number of the file"
required: true
example: 1
selector:
number:
max: 10000
min: 1
step: 1
sequence:
file: "{{ file | int(1) }}"
mode: single
icon: mdi:music
stevemann
October 1, 2023, 11:41pm
9
Thanks for the tip, but I am getting another error:
Failed to call service script/play_mp3_file. Error rendering data template: UndefinedError: 'file' is undefined
Reading this (passing variables to scripts ) confused me more.
