I just upgraded from 0.80.x to 0.90.2 so of course now Lovelace has taken over. But I am lost on how to manage it. My interface still looks the same as before I updated but when I try to add items to groups.yaml nothing happens. So I started trying to research how to manage the UI.
I watched a video on how to manage the UI and it says I can just edit directly in the browser by clicking on the menu and clicking on “Configure UI”. When I do that I get a warning that I am taking control and can’t turn back.
Should I take control?
Can I still manage my UI from files or do I have to use the editor now?
I tried reading docs and watching videos but they don’t seem to match what I am seeing. I guess this stuff is getting changed so quickly it’s hard to keep up.
You can either use the ui or files, not really both (although some people use files and paste into an editor provided by the ui). Neither option is irreversible, so you can have a play.
Anything you do in the ui is available as text in the raw editor so if you decide to go to manual mode you can copy anything you’ve done to your ui-Lovelace.yaml.
I have two instances. One at work and one at home. I upgraded my work instance a few weeks ago but couldn’t find a way to switch back once I clicked on “Take control”. How do you switch back to letting home assistant manage the ui?
I don’t even have a ui-Lovelace.yaml file. I don’t see any way to mange the UI in the current mode. Changing my yaml files doesn’t do anything and there is no editor interface. I am guessing I should just click on “Take Control”
I don’t see this option. Not on users page (that seems a strange place to find it). Not on any other configurations page.
Perhaps you guys are using hass.io? I am using hassbian, I thought they were same but maybe not.
I had done that on my work instance and there was a lovelace.yaml file for that instance but when I upgrade to 0.90.2 the file stopped working.
My understanding is that when I upgraded to 0.90.2 on my home instance lovelace became the default ui.
It’s documented in the 0.86 release notes.
So without the lovelace: entry in my configuration am I NOT using lovelace yet. I thought it was the default now. My ui control yaml files don’t seem to work anymore so I figured I was in lovelace mode.
I ckecked again and the option is actually on the ‘dev-info’ page on the developer tools, the right most icon with the i in a circle.
It’s the page with this info:
Home Assistant
0.90.2
Path to configuration.yaml: /config
Developed by a bunch of awesome people.
Published under the Apache 2.0 license
Source: server — frontend-ui
Built using Python 3, Polymer, Icons by Google and MaterialDesignIcons.com.
Frontend JavaScript version: latest
Go to the Lovelace UI
