I am trying to get a blinds roller up and running, and everything seems to be working okay except for the fact that when I control the device in home assistant, both the open and close buttons rotate the stepper motor in the same direction.
I am using the yaml found here here: Direction doesn't always work · Issue #980 · esphome/issues · GitHub
And using the schematic found here: Home assistant automated blinds — Mellow Fire
I tried a few things in the yaml but nothing is changing the way the motor spins with either the open or close command.
Any help is greatly appreciated!
