Can someone with a Shelly2 do a quick test for me please?
Hi there,
Can someone do me a huge favour and replicate my config below with one relay configured as a light and the other as a switch? Then turn them both on and then restart the HA service and tell me if (only) the light turns off. If you have a Shelly2 configured already, you only need to change the first line.
light:
  - platform: mqtt
    state_topic: "shellies/shellyswitch-9F6008/relay/1"
    command_topic: "shellies/shellyswitch-9F6008/relay/1/command"
    qos: 2
    payload_on: "on"
    payload_off: "off"
    retain: false
    optimistic: false
switch:
  - platform: mqtt
    name: "Family Room Fan"
    state_topic: "shellies/shellyswitch-9F6008/relay/0"
    command_topic: "shellies/shellyswitch-9F6008/relay/0/command"
    qos: 2
    payload_on: "on"
    payload_off: "off"
    retain: false
If you could also report whether you are using stock or Tasmota firmware, that would be appreciated. For me, HA is sending shellies/shellyswitch-9F6008/relay/1/command with a payload of 'on' when the HA service restarts but only for MQTT lights, not the switch.
Seems this has been resolved in 0.82.0/0.82.1. Without changing any code of mine, restarting HA with the lights on no longer turns them off.
