Can’t add Truenas SMB share to HA Green…. Need data storage soon
Hello ALL,
I have Truenas set up on an old dell r510. That server resides on its own subnet. I have firewall rules set to pass all SMB and ZFS ports (137, 138, 139, 445, 2049, and 111) through from the HA Green to the server in both directions. I set up an SMB and a ZFS share for backups (tried both ways from the HA green)
I do not have computer that is working right now to test windows connections, but I can see the server on my iPad and can read/write to the share using the same user name and password.
Here are the latest error logs:
There are a couple where I had too many “/“ in the path…. But the top one gives very little information.
I am new ish to HA and Truenas. I appreciate any help.
I can not offer any advice based on those errors. As you stated, there is not much to go on.
I’m backing up from Home Assistant Blue to TrueNAS Scale using NFS.
Here are my settings. Maybe it will help.
TrueNAS
Home Assistant
Maybe you helped with my issue…. I have the pool name but not /mnt/. I will try that next.
Thanks!
