Hi. I am very new to I can’t get my ZHA to set up with my HUSBz1. I am using Home Assistant OS on a Raspberry Pi4
I am getting the following error log
Logger: homeassistant.config_entries
Source: components/zha/core/gateway.py:173
First occurred: 11:27:10 PM (3 occurrences)
Last logged: 11:34:14 PM
Error setting up entry HubZ Smart Home Controller - HubZ ZigBee Com Port, s/n: 11600106 - Silicon Labs for zha
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 339, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/zha/__init__.py", line 102, in async_setup_entry
await zha_gateway.async_initialize()
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 173, in async_initialize
self.application_controller = await app_controller_cls.new(
File "/usr/local/lib/python3.9/site-packages/zigpy/application.py", line 61, in new
await app._load_db()
File "/usr/local/lib/python3.9/site-packages/zigpy/application.py", line 53, in _load_db
await self._dblistener.load()
File "/usr/local/lib/python3.9/site-packages/zigpy/appdb.py", line 491, in load
await self._load_node_descriptors()
File "/usr/local/lib/python3.9/site-packages/zigpy/appdb.py", line 573, in _load_node_descriptors
async with self.execute(f"SELECT * FROM node_descriptors{DB_V}") as cursor:
File "/usr/local/lib/python3.9/site-packages/aiosqlite/context.py", line 41, in __aenter__
self._obj = await self._coro
File "/usr/local/lib/python3.9/site-packages/aiosqlite/core.py", line 184, in execute
cursor = await self._execute(self._conn.execute, sql, parameters)
File "/usr/local/lib/python3.9/site-packages/aiosqlite/core.py", line 129, in _execute
return await future
File "/usr/local/lib/python3.9/site-packages/aiosqlite/core.py", line 102, in run
result = function()
sqlite3.OperationalError: no such table: node_descriptors_v8
Any help would be greatly appreciated!
