Can‘t Connect to HA-Server via DuckDNS with new Modem
my old Modem Broke and I could Not Backup my settings. So the new one does not have the port forwards set up that I need for DuckDNS connection. I set up the DNS 4 years ago so I cannot remember what port I used.
So what would you recommend to restore this? I can see in my router that the HA-Server is connected to the same local IP but as expected I cannot connect using that one.
How do I get in again?
Forward 8123 to 8123 on the HA server IP
And just to be sure, 443 to 8123 on the HA server IP
That Worked Right away. Thank you
