Can’t control Danalock v3 HA 0.71 (Z-Wave)
Hi all,
I’m new to HA. It’s been many years that i have been away from the hole open source world - but i managed to setup a Intel Nuc with Ubuntu, for video surveillance with Unifi video + Unifi Network management. On top Docker - with a GUI and here i installed HA, normally been using Samsung Smartthings - so from a very easy world going into a more hardcore world. :slight_smile:
I have setup HA to run in Docker, with my Z-stick gen5 with security key etc etc - it speaks fine with Fibaro motion sensors etc.
My problem is that my Danalock V3 is not working with version 0.71 of HA.
It has found the Lock, but its always showing up as READY and not sleeping, firmware on the Danalock is 0.8.2 = the newest one.
I did add the lock from within the Gui of HA - selecting ADD NODE secure, 10 cm’s from HA.
The lock has the following info:
ode id
6
node name
Polycontrol Danalock V3 BTZE
manufacturer name
Polycontrol
product name
Danalock V3 BTZE
query stage
Complete
is awake
true
is ready
true
is failed
false
is info received
true
max baud rate
40000
is zwave plus
true
capabilities
beaming, routing, frequent
neighbors
1, 7
sentCnt
25
sentFailed
7
retries
0
receivedCnt
0
receivedDups
0
receivedUnsolicited
0
sentTS
2018-06-12 20:28:32:298
receivedTS
2018-06-12 09:30:20:810
lastRequestRTT
2564
averageRequestRTT
3074
lastResponseRTT
0
averageResponseRTT
0
battery level
Its funny to see how many that has had issues, but i don’t know what to do from here, my skills does not allow me any further currently, so i’m hoping some HA expert in here has a next step to try.
In the logs i can see HA sends commands to the lock but nothing happens.
2018-06-12 20:27:18.170 Detail, Node007, Removing current message
2018-06-12 20:28:22.296 Info, Node006, Value::Set - COMMAND_CLASS_DOOR_LOCK - Locked - 0 - 1 - True
2018-06-12 20:28:22.296 Info, Node006, Value_Lock::Set - Requesting lock to be Locked
Does the Docker image have all of the needed openZwave stuff? I did se some adding a speciel .xml file for the lock to work, but is that needed in the new HA 0.71 or when running in Docker?
I just added a Danalock v3 to HA as well on 0.71. Should it be showing up as Sleeping? For me it shows as Ready.
Control of the lock through Zwave works fine, but it shows up as Unknown Node 9.
I have also danalock in status Ready, but I do not know how to lock or unlock the door,
Should I write some entity_registry ? or how is it working ? I am new in HA.
Here is my output from Danalock, if I click on lock door,
Then I see in my zwave Aeotec ZW090 Z-Stick Gen5 EU, but is not locking nothing.
2018-08-22 23:07:44.486 Info, Node005, Value::Set - COMMAND_CLASS_DOOR_LOCK - Locked - 0 - 1 - True
2018-08-22 23:07:44.486 Info, Node005, Value_Lock::Set - Requesting lock to be Locked
2018-08-22 23:07:44.487 Detail, Node005, Queuing (Send) DoorLockCmd_Set (Node=5): 0x01, 0x0a, 0x00, 0x13, 0x05, 0x03, 0x62, 0x01, 0xff, 0x25, 0x15, 0x4c
2018-08-22 23:07:44.487 Detail, Node005, Queuing (Send) DoorLockCmd_Get (Node=5): 0x01, 0x09, 0x00, 0x13, 0x05, 0x02, 0x62, 0x02, 0x25, 0x16, 0xb1
Just for your information: I (and others) seem to have a similar issue with incomplete inclusion and ‘always ready’ symptoms: Another Danalock v3 config. Thread
