I am trying to create a package that translates my simple ceiling fan with three speeds (via remote) as a HomeAssistant-fan.
I have created a fan template that controls the fan via various scripts. Unfortunately these scripts are not found.
Error when calling the service fan/turn_on. Unable to find service script.wohnzimmer_fan_switchon
But the script exists. I’ve been tearing my hair out for two weeks now. Can anyone help me? What’s wrong with this package?
# Keep track of the fan state
input_boolean:
wohnzimmer_fan_state:
# Keep track of fan speed
input_number:
wohnzimmer_fan_percentage:
name: Wohnzimmer Ventilator Prozent
min: 0
max: 100
fan:
fans:
wohnzimmer_fan:
friendly_name: "Wohnzimmer Ventilator"
unique_id: wohnzimmer_fan
value_template: "{{ states('input_boolean.wohnzimmer_fan_state') }}"
percentage_template: "{{ states('input_number.wohnzimmer_fan_percentage') }}"
turn_on:
service: script.wohnzimmer_fan_switchon
turn_off:
service: script.wohnzimmer_fan_switchoff
set_percentage:
service: script.wohnzimmer_fan_set_speed
percentage: "{{ percentage }}"
script:
wohnzimmer_fan_switchon:
alias: Ventilator einschalten
sequence:
- alias: Ventilator auf low schalten
service: wohnzimmer_fan_low
- alias: Status auf on setzen
service: input_boolean.turn_on
entity_id: input_boolean.wohnzimmer_fan_state
- alias: Prozent auf 33 setzen
service: input_number.set_value
entity_id: input_number.wohnzimmer_fan_percentage
value: 33
mode: single
wohnzimmer_fan_switchoff:
sequence:
- alias: Ventilator ausschalten
service: wohnzimmer_fan_off
- alias: Status auf off setzen
service: input_boolean.turn_off
- alias: Prozent auf 0 setzen
value: 0
mode: single
wohnzimmer_fan_set_speed:
sequence:
- service: input_number.set_value
value: '{{ percentage }}'
- choose:
- conditions:
- condition: numeric_state
above: 83
sequence:
- service: script.wohnzimmer_fan_hi
- conditions:
above: 50
sequence:
- service: script.wohnzimmer_fan_mid
- conditions:
above: 33
sequence:
- service: script.wohnzimmer_fan_low
default:
sequence:
- service: script.wohnzimmer_fan_off
mode: single
wohnzimmer_fan_off:
action: call-service
service: remote.send_command
device: Ventilator
command: Off
device_id: 24c8fd2e58f1ff37b0ff9ab382e6de11
wohnzimmer_fan_low:
device: Ventilator
command: Low
wohnzimmer_fan_mid:
device: Ventilator
command: Mid
wohnzimmer_fan_hi:
device: Ventilator
command: Hi
CO_4X4
(Colorado Four Wheeler)
August 8, 2022, 3:30pm
2
Are you able to run those scripts manually from Developer? If not then you can’t run them via a template either. If both can’t find them then check your logs to see if the scripts aren’t loading because of a problem.
finity
August 8, 2022, 5:36pm
3
the only thing I see is that your indentation under the “script:” header is different from the ones above. That might cause issues.
try moving everything under “script:” back to the left 2 spaces:
script:
sequence:
value: 33
mode: single
sequence:
My goodness, that was a tough one. Some lines of it I had apparently from old tutorials and I fear I will never really understand YAML.
In the end, I clicked most of it together in the script editor to get the indentations right. Sometimes something is indented, sometimes a dash is put in front of it. This has nothing to do with the other programming languages I usually use.
And such error messages are not very helpful either. Sigh.
Got None. (See ?, line ?).
But here it is, this code works. Maybe someone can do something with it.
input_boolean:
input_number:
min: 0
max: 100
fan:
fans:
wohnzimmer_fan:
friendly_name: Wohnzimmer Ventilator
turn_on:
turn_off:
set_percentage:
script:
sequence:
value: 33
mode: single
icon: mdi:fan
sequence:
value: 0
mode: single
icon: mdi:fan-off
sequence:
- choose:
- conditions:
above: "79"
sequence:
data: {}
- conditions:
above: "49"
sequence:
data: {}
- conditions:
above: "0"
sequence:
data: {}
default:
data: {}
mode: single
icon: mdi:fan-plus
wohnzimmer_fan_off:
sequence:
- service: remote.send_command
entity_id: remote.wohnzimmer_remote
device: Ventilator
command: 'Off'
icon: mdi:fan-off
wohnzimmer_fan_low:
sequence:
device: Ventilator
command: 'Low'
icon: mdi:fan-speed-1
wohnzimmer_fan_mid:
sequence:
device: Ventilator
command: 'Mid'
icon: mdi:fan-speed-2
wohnzimmer_fan_hi:
sequence:
device: Ventilator
command: 'Hi'
icon: mdi:fan-speed-3
Now I have also slowly understood that a script in which there is even a small error is not even recognized and immediately acknowledged with "Unable to find service ".
I have shortened the code even further and improved the functionality. Switching on and off are now decoupled from the speed. I.e. if you switch off at 100%, it will be set to 100% again when you switch on. If you pull the slider to 0%, the fan is switched off.
input_boolean:
input_number:
min: 0
max: 100
fan:
fans:
wohnzimmer_fan:
turn_on:
turn_off:
set_percentage:
script:
sequence:
data: {}
- choose:
- conditions:
below: '1'
sequence:
value: '33'
- service: script.wohnzimmer_fan_set_speed
percentage: '{{ states(''input_number.wohnzimmer_fan_percentage'') }}'
mode: single
icon: mdi:fan
sequence:
- service: input_boolean.turn_off
- service: script.remote_send_command
command: 'Off'
mode: single
icon: mdi:fan-off
sequence:
- choose:
- conditions:
above: '79'
sequence:
command: Hi
- conditions:
above: '49'
sequence:
command: Mid
- conditions:
above: '0'
sequence:
command: Low
default:
- service: script.wohnzimmer_fan_switchoff
mode: single
icon: mdi:fan-plus
remote_send_command:
sequence:
device: Ventilator
command: '{{ command }}'
icon: mdi:remote
Hi, could you help me with this script ? I want to use it to control a AC fan. (5 settings based on xx %)
I tried pasting the code into “scripts” (menu automations and scripts) , but immediately got an error “Message malformed: extra keys not allowed @ data[‘input_boolean’]” Or how do I go about this?
Also, I need to change the entity id’s I guess ? Anything else I need to consider?
