Hi
i have a problem with the following code, and i can not find the root cause why the code i not working. maybe someone have an idea
substitutions:
device_name: max7219_2
#device_description: Display für Temperatur
#friendly_name: max7219_2
esphome:
#comment: ${device_description}
platform: ESP8266
board: d1_mini
#arduino_version: 2.4.2
wifi:
ssid: !secret wifi_ssid
fast_connect: on #we only have one WiFi AP so just use the first one that matches
ap: #since we listed an SSID above, this AP mode will only enable if no WiFi connection could be made
ssid: ${friendly_name}_AP
password: my_pw
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
web_server:
port: 80
- platform: homeassistant
entity_id: sensor.netatmo_wohnhaus_wohnzimmer_temperature
internal: true
entity_id: sensor.netatmo_wohnhaus_wohnzimmer_aussen_temperature
internal: true
time:
font:
- file: "pixelmix.ttf"
globals:
- id: my_global_bool
type: bool
restore_value: no
initial_value: 'true'
spi:
clk_pin: D5
mosi_pin: D7
display:
- platform: max7219digit
cs_pin: D8
num_chips: 12
intensity: 9
lambda: |-
if (id(ofen_temp1).state < 40 || id(ofen_temp2).state < 40) {
it.strftime(0, 4, id(digit_font), TextAlign::CENTER, "%A %d. %B %Y %H:%M:%S", id(hass_time).now());
else if ((id(my_global_bool)) && (id(ofen_temp1).state > 40 || id(ofen_temp2).state > 40)) {
it.printf(0, 4, id(digit_font), TextAlign::CENTER, "Temp-O: %.1f°C", (id(ofen_temp1).state));
else {
it.printf(0, 4, id(digit_font), TextAlign::CENTER_LEFT, "Temp-U: %.1f°C", (id(ofen_temp2).state));
#lambda: |-
# it.printf(0, 4, id(digit_font), TextAlign::CENTER_LEFT, "Holzofen: %.1f°C", (id(ofen_temp1).state));
# it.scroll(true,1,100,1000,1000);
# For example cycle through pages on a timer
interval:
- interval: 2s
then:
- lambda: |-
if (id(my_global_bool)) {
id(my_global_bool) = false;
else {
id(my_global_bool) = true;
