I have a sonoff dongle 3.0 E drive. I initially got it up and running on zigbee after flashing with latest firmware.
But then my SD card died so i had to reflash my pi with homeassistant.
Now, when I try to connect to z2m, I get the following error message
z2m: Error: spawn udevadm ENOENT
at Process.ChildProcess._handle.onexit (node:internal/child_process:284:19)
at onErrorNT (node:internal/child_process:477:16)
at processTicksAndRejections (node:internal/process/task_queues:82:21
My configuration is as follows:
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
mqtt:
mqtt:
base_topic: zigbee2mqtt
server: mqtt://[ip address]:1883
user: mqtt_user
password: [password]
serial:
Port: >-
/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_62c940386cafed11bdea394e71c9e8b5-if00
adapter: ember
