Hello, have Home Assistant 2022.9.4. Somewhere around version 2022.8 version I noticed strange problem. I can login from my local network. But not from outside (via myowndomain:8123). I run on http only. It shows login but after I will use credentials it shows bad username or password. I checked multiple times all is right written.
I use TOTP and everything worked before without any problem. Log is empty.
Tried to clear the browsers cache ?
And what happens when you use the anonymous mode of the browser or browser from some other device? (which is basically the same as using anonymous mode)
Well…maybe one thing. I tried to install reverse (few weeks ago) proxy using Nginx and Nginx proxy manager. I installed both but was not able to get it work. So I uninstalled. Maybe this is the point (I can´t remember exaxctly) when login stopped working. So maybe this could be some problem. Maybe it causes some setting change somewhere… but where to search for?
I never used the reverse-proxy of HA, so hopefully someone else has knowledge about it.
Have you tried the remote access using your IP instead of the domain name?
Holly s*** - my mystake. Sorry. I made domain name for my friend and forgot it. Now I thought his domain name is mine… So I tried to log into his instance of HASS.
