Hello to all, I´m using hassos 1.13 and hassio 0.92.2, but I tried to make a snapshot before update but it isn´t working and when I tried to see my directories in my PC my samba isn´t working as well, here the logs:
PANIC (pid 57): reinit_after_fork() failed
unable to produce a stack trace on this platform
coredump is handled by helper binary specified at /proc/sys/kernel/core_patternmessaging_dgm_lockfile_create: write failed: No space left on device
messaging_dgm_init: messaging_dgm_create_lockfile failed: No space left on device
messaging_dgm_ref failed: No space left on device
messaging_reinit() failed: NT_STATUS_DISK_FULL
Remove the card from the pi and use a linux PC to move some files off the card (e.g. snapshots and possibly home-assistant_v2.db). If you don’t have a linux PC use a bootable live CD.
Live CDs are a way to try linux without installing it.
E.g. download the free Ubuntu image, burn the image to a USB drive and boot your PC from the USB drive. Select the live option not install when it boots.
Or use software under windows that can read and write to linux partitions. E.g. software like this can do it:
If I understand correctly just download the software and insert the card with homeassistant than I´ll be able to write/erase the files? is homeassistant written in * Ext2
My card is 32gb and was full mostly due to the home-assistant_V2, that was 13gb, I cleared this and the backups and restart from putty and worked again.
