I’m using the old style interface and am using groups.yaml to show devices in groups.
Since we can see battery status now I wanted to group the entities having a battery status. But to my surprise that does not work. Having only battery entities in the group will not show the group on the webpage. If I add a normal device to the same group the group shows with that one device, but the battery entities aren’t shown.
The States UI is dead. It died in 0.107. If you’re on 0.114 then you’re using Lovelace. It’s time to learn how that works and stop trying to use groups
i 2 still use groups and all work except for the battery status, i want to know if you found a solution ?
if you add them to a group they do disappear in the top row but not all appear in the group. out of 12 battery’s only 6 show.
What are you trying to do? There’s various custom battery status cards that may cover what you want. I quite like this one but there are other options.
i just want to see the battery status grouped together, in the default view, now i have the half on top and the other half in a group (the ones that show up in a group)
No, I’ve not found a solution to the partly incorrect working of group.yaml. Up to now group.yaml seems to not apply to battery (anymore?) and I also found that iPhone entities do not group as well.
Today I upgraded to release 115.2 and the iPhone entities are now in a separate group as configured in groups.yaml and are not shown anymore in the top section of the UI.
