Can’t update to 6.4
When I’m trying to update from HA I have this message:
Can’t fetch OTA update from https://github.com/home-assistant/operating-system/releases/download/6.4/haos_rpi4-64-6.4.raucb: Cannot connect to host github.com:443 ssl:default [None]
I tried with SSH but same
➜ ~ hassio hassos update The ‘hassio’ command is deprecated, please use ‘ha’ instead! The use of ‘hassos’ is deprecated, please use ‘os’ instead! Processing… Done.
Error: Can’t fetch OTA update from https://github.com/home-assistant/operating-system/releases/download/6.4/haos_rpi4-64-6.4.raucb: Cannot connect to host github.com:443 ssl:default [None] ➜ ~ hassio hassos update
for information I’m using CloudFlare for Family for my IoT VLAN (DNS 1.1.1.2./1.1.1.3)
I also temporarily turned of DPI on my gateway but same issue.
I have the same problem
## Aggiornamento non riuscito
Can't fetch OTA update from https://github.com/home-assistant/operating-system/releases/download/6.4/haos_rpi4-6.4.raucb: Cannot connect to host github.com:443 ssl:default [Connect call failed (' ... ', 443)]
Can’t remember how I fixed it sorry.
I think the issue was with my gateway (Ubiquiti/UniFi) but I’m not sure.
I did reboot the host and fixed. :slightly_smiling_face:
