I have somewhat of an understanding of the Trigger State node. From what I can figure out is that if you have several contraints they all need to be satisfied before the allow is opened.
Is there a way to make it with an “or” condition?
For example, if my phone connects to wifi OR life360 shows me as home, mark me as home.
As @oembob mentioned, the person entity is probably the best option for this.
I used to use a complicated setup with functions that checked state of the trigger, and other entities to verify home/away. Now I just use a person node and it makes it so much simpler.
2 interesting points. One is I spent about 2 hours looking for your old post that gave me inspiration for this question. I remember you saying you had a flow you preferred. But times change.
Second point (let’s ignore the device tracker scenario) can the trigger node be used as an ‘or’ condition or would we just use a simple switch node connected to several trigger nodes?
I know this is an old thread, but I’m interested in this as well.
From my uni days, I recall that an OR gate can be constructed by inverting the inputs and using a NAND gate. So, I think you’ll get an OR function by reversing the various comparisons and using the Failed output for your message.
