When I try to use the google_translate service in the HA UI, it only lists media devices and not my computer or phone. Is there a way to make that work?
With computer choose browser. Not sure how to do it with phone.
On my android phone I use notify and pushover to get google tts voice notifications.
Search for notify and pushover to set up your accounts.
My YAML Code:
notify:
- platform: pushover
api_key: aibcq6ekfj4uztdb7uzvxxxxx2o7
user_key: uijfrfqp7ri235z8xxxxxk2vrzj4gd
notify:
api_key: aibcq6ekfj4uztxxxxxv7v7z2if2o7
user_key: uijfrxxxx7ri235z82nhyik2vrxxxxx
Chas
The browser mod custom integration can create a browser based media player for both your computer and/or mobile browsers.
For mobile, tts using the mobile app integration works well also.
browser mode creates media of each device but no tts option in more info…what am i missing ?
TTS was removed from the more-info dialog.
You either need to use Developer Tools > Services to call a TTS service, or a script or automation.
could you share some example ?
Here is an example from a script:
alias: Test Speak
sequence:
- service: tts.google_translate_say
entity_id: media_player.bedroom_clock
message: This is a test
mode: single
You could create an input_text helper in the settings menu and then use the value of that to speak:
alias: Test Speak
sequence:
message: >
{{ states('input_text.my_tts_text') }}
mode: single
Or you can make a script that accepts these as inputs to the script:
fields:
tts_target:
description: The media_player to target
example: media_player.bedroom_clock
tts_text:
description: The TTS we want to speak
example: This is a test
alias: Test Speak
sequence:
entity_id: {{ tts_target }}
message: >
{{ tts_text }}
mode: single
Thanks for sharing I tried few but none works …does tts work on browser mode media ? And alexa media player? I tried on them but no response
