hi, i want to transfer my CSV file from my homeassistant to my client homeassistant is there a way to do it?. I’ve tried several ways but nothing works
Not natively in HA, no.
There are however many different ways of solving that, depending on how those to are able to talk to each other. Using a shell command with SCP to copy the file over SSH would be the easiest, if those two can communicate directly.
hi tinkerer thanks for the answer do you have any idea how the two can communicate directly because till now i can only use remote home assistant but it only transfers sensor values not the CSV file
Well, can the two communicate directly already?
If they can, then the next steps are easy. If they can’t then you’re going to need some form of VPN first.
