Can Xiaomi LLKZMK11LM measure with confidence only energy for both channels? - Alternative devices?
I’ve owned four nice Xiaomi LLKZMK11LM relays for over 1 year. Now I have installed them and had to notice shocked that the energy value probably measures both channels as one value :open_mouth:
In my head I thought I could switch with the LLKZMK11LM two connected 230v channels and also measure the watts, independently of each other.
I would like to find someone with original aqara or xiaomi base who can confirm this to me on the latest firmware (from the LLKZMK11LM and the zigbee base). Some screenshots from the app + settings (like this one https://imgur.com/a/mBz1MQB) would be awesome.
Currently I run the LLKZMK11LM with zigbee2mqtt. In the Homeassistant these values / options are available:
Here again the link from z2m to the device:
Maybe you know alternative relays. All that I have found so far on zigbee basis can not measure any current according to the dealer or manufacturer:
This device is genious but sonoff just build it with wifi :frowning:
This device could be my soultion if it would be cheaper:
https://www.lupus-electronics.de/shop/Alarm-Smarthome/Smarthome-Hausautomation/LUPUS-2-Kanal-Relais-mit-ZigBee-Repeater-p.html
I know there a some smart-sockets on the market but I really want relay’s.
Greetings by JamieMe
