Tekza
December 17, 2020, 6:32am
1
I’m trying to do some gauge complications for the Apple Watch. I’d like to do a gauge but I’m not sure how to make one that doesn’t start with 0. Right now my gauge code is
{{ states("sensor.dc_voltage") | float / 29 }}
I’m trying to define my gauge range as 25 - 29 and the sensor result should fall in that. The problem is even if the Voltage was 25 that’s still 86% of 29 and it shows the bar nearly full. So is it possible to create a gauge for a limited range and have the result show correctly? Do I need to figure out how to convert my range to 100 and then apply that same to the result?
GlennHA
(Glenn)
December 17, 2020, 2:34pm
2
Simple answer, yes.
You could easily make it a percent, which might be more useful.
Not having all the information below seems like what you are really wanting.
{{ ((states("sensor.dc_voltage") | float) -25 ) / 29 }}
Or, you can use a custom bar graph and set the min max (you stated bar).
Or you can use a canvas gauge.
Are you trying to display this on the watch? or get voltage from the watch?
type: 'custom:auto-entities'
sort:
method: entity_id
numeric: true
card:
type: 'custom:bar-card'
severity:
- color: '#0513eb'
to: '30'
- color: '#34bdeb'
to: '50'
- color: '#68c843'
to: '55'
- color: '#68aa43'
to: '60'
- color: '#ffff55'
to: '65'
- color: '#ef8533'
to: '70'
- color: '#ea3324'
to: '75'
- color: '#8c1a4b'
to: '80'
- color: '#731425'
to: '100'
min: '0'
max: '100'
icon: ''
decimal: 1
height: 16
positions:
value: inside
indicator: outside
icon: 'off'
minmax: 'off'
show_header_toggle: false
title: ''
show_empty: false
filter:
include:
- entity_id: '*dewpoint*'
exclude:
- entity_id: '*description*'
type: 'custom:canvas-gauge-card'
card_height: 300
entity: sensor.purpleair_aqi_a
gauge:
type: radial-gauge
title: AQI
width: 300
height: 300
minValue: 0
maxValue: 500
startAngle: 40
ticksAngle: 280
valueBox: true
majorTicks:
- '0'
- '50'
- '100'
- '150'
- '200'
- '250'
- '300'
- '350'
- '400'
- '450'
- '500'
minorTicks: 10
strokeTicks: true
highlights:
to: 50
color: 'rgba(104, 225, 67, .75)'
to: 100
color: 'rgba(255, 255, 85, .75)'
to: 150
color: 'rgba(239, 133, 51, .75)'
to: 200
color: 'rgba(234, 51, 36, .75)'
to: 300
color: 'rgba(140, 26, 75, .75)'
to: 500
color: 'rgba(115, 20, 37, .75)'
borders: 'no'
needleType: arrow
needleWidth: 4
needleCircleSize: 7
needleCircleOuter: true
needleCircleInner: false
animationDuration: 1500
animationRule: linear
valueBoxBorderRadius: 10
colorValueBoxRect: '#222'
colorValueBoxRectEnd: '#333'
valueDec: 0
valueInt: 0
fuse1
March 27, 2021, 7:24pm
3
How would I do this for a temperature range? The following gives a negative result for me (-0,666667):
{{ ((states("states.sensor.ironing_room_temperature") | float) -16 ) / 24 }}
I would like the temperature range to be between 16 and 24.
{% set original = states("states.sensor.ironing_room_temperature") | float %}
{% set minimum = 16.0 %}
{% set maximum = 24.0 %}
{% set constrained_original = [maximum, [minimum, original] | max] | min %}
{{ (constrained_original - minimum) / (maximum - minimum) }}
fuse1
March 28, 2021, 6:59am
5
Hmm, the preview output unfortunately still returns “0”, even though the sensor value is around 19.
fuse1
May 1, 2021, 3:21pm
6
It works, thank you! For some reason the watch needs some time to ‘save’(?) what’s entered in the input field. Works like a charm!
