- alias: 'Turn on exhaust fan every hour when its 90 degree hot outside'
platform: time
hours: '/1'
minutes: 00
seconds: 00
condition:
- condition: numeric_state
entity_id: 'sensor.pws_feelslike_string'
above: '89'
- service: homeassistant.turn_on
entity_id: switch.switch_3
I think your problem is the sensor you are using. It’s the string (which is text). You’d be better off using sensor.pws_feelslike_f instead since it’s numeric. Also, I don’t think you need ‘’ around the entity_id nor the above.
thank you… that one works… solved my problem
