Hi there,
I’m pretty new here and I’m switching from Domoticz to HA.
I’m beginning to understand the deeper concept of HA and HAOS.
I must confess that I thought that HA was similar to Domoticz on the Raspberry.
Before getting in to dashboards en automation, I first want to get all my hardware connected.
Almost everything works, but for my Alarm.
I have an NX-584 based system and aanstaande far as I know there is no integration or add-on for this system. I found out that I have to install pynx584 from Github and then I can address that when I add some lines to the configuration.yaml file.
Now I’m stuck with installing pynx584 on my HA Yellow.
I suppose I’m using the HAOS and therefore can’t install the Python based files.
Normally I would SSH and use the following line to install:
“# pip install pynx584”
But this doesn’t work with the internal SSH and the HAOS.
Is it correct that I can’t make this work with HAOS?
Any help is much appreciated.
Regards,
Willem-Bram
