Can you put a home assistant address in a subpath?
Good day,
want to insert home assistant in a sub path of a domain or ddns, can it be done?
I would like to use NGINX
example:
https://domain.io/homeassistant
https://domain.duckdns.org/homeassistant
It’s not supported. See https://github.com/home-assistant/core/issues/21113
I think they should take this into consideration because it seems useful to me if not, you always have to specify the port or create a 3rd level domain or a second ddns if you want to expose more platforms
can’t even use NGNIX?
Yes, you can use nginx
You just have to use 3rd level domains, e.g. I have
I also have this configuration with a 3 level domain, but I would need to use a subpath
https://domains.io/homeassistant
You can’t. Home Assistant doesn’t support it, as per the github issue I linked. It doesn’t matter what reverse proxy you use.
Use a subdomain.
for more sub-domains how networks are managed in italy would need more ddns clients and this is not possible for me
I don’t understand. If you have a domain xyz.tld you can do anything you like with it.
Anyway what you ask is not possible so you have to find a domain solution.
I use cloudflare (free) and my subdomains are just c-names pointing to my main domain. So just 1 ddns client needed. And there is a nice add-on to manage. search for letsdnsocloud on the forum.
ok, but if you want to open more subdomains
example:
home.domain.io
nodered.domain.io
homeaasistant.domain.io
ecc…
networks are managed with dynamic ip and I can only manage via ddns that need a client to update the ip.
I have already tried this problem
thanks, i am using either duckdns or google domains
I opened a thread with a request to add this works, I hope they take it into consideration and that we can discuss the matter
I’m sure google domains knows the concept of a c-name.
yes, but I’m using the google domains ddns function and I don’t know if I can tell him to use only the same ip for more ddns, at least I haven’t found this function
Use dns for one hostname in your domain. Add a cname for one or more other names to that first hostname. Problem solved.
in the end it will be what I will do if the function cannot be added
It was already decided by the team that this won’t be added:
From a core dev (not naming so they don’t get spammed to hell, but you can see in ^ that ticket):
This will involve a LOT of work to both the backend and the frontend. And it will add work to each new feature/integration added, too. Or let alone the idea that a user would want to change the hosted path and all the config that now needs to be updated.
I don’t think it’s worth the effort to get there nor the effort to maintain it.
ok, thanks
