Can you upgrade existing Raspbian to Hass.io?
Dumb question I’m sorry, can I upgrade the most recent version of Raspbian I have to Hass.io or do I need to start fresh? Thanks in advance!
You need to start fresh. However, you do not need to make a new config. Copy the contents of your config directory (via your preferred file sharing method like Samba or NFS) to a local folder on your computer excluding the “deps” folder. If you have any custom scripts, etc, save them to your PC as well.
You’ll need to image your SD card with the latest Hassio image and get a base install of Hassio going. Next, install the Samba addon (Go to the Hassio icon on the sidebar then click this) https://home-assistant.io/images/hassio/screenshots/main_panel_store_icon.png. Then click install, and once it’s done configure it via the instructions here.
Copy over your config, and pray it works. I’ll be happy to help you troubleshoot any potential issues if you decide to switch.
Awesome thank you so much!
