How do I listen to all can_id
's? From the documentation I gather that setting can_id_mask
to 0 should accomplish that, but in this case I get no messages at all.
Listening to specific can_id’s works as expected.
I too am trying to receive all can_id’s
Did you find a solution?
I’m wondering if it can be done in lambda, similar to sending via lambda
This works for me:
canbus:
- platform: esp32_can
tx_pin: GPIO25
rx_pin: GPIO26
can_id: 100 # can id for transmitting frames
bit_rate: 250kbps # rv-c
on_frame:
- can_id: 0 # listen to all messages
can_id_mask: 0
use_extended_id: true
then:
- lambda: |-
char buf[29];
// DGN
// Source Address (SA)
// Priority
// Data (8 bytes)
int dgn = (can_id >>8) & 0x1ffff;
int pri = (can_id >> 26) & 0b111;
int sa = can_id & 0xff;
snprintf((char*)&buf, sizeof(buf), "%05X,%02X,%1X,%02X%02X%02X%02X%02X%02X%02X%02X", dgn, sa, pri, x[0], x[1], x[2], x[3], x[4], x[5], x[6], x[7]);
id(rvc_rx).publish_state((const char*)&buf);
ESP_LOGI("can", "%s", (const char*)&buf);
it won’t work in 2024
Why won’t it work? no longer supported?
I’m interested in knowing how to do this as well, if using 0 isn’t the correct way anymore.
