I’m trying to make motion light app and now i’m completely lost. It works most of time but sometimes if just fails. I use xiaomi motion sensor and when there is motion it stays on for 1 minute then wait for 100 seconds to turn light off when it goes to off. Here is my log when it works ok:
2017-12-27 17:33:20.342212 INFO bathroom_light_day: Light on because motion is on
2017-12-27 17:38:36.029955 INFO bathroom_light_day: Set brightness to 30 and turn off light in 10 seconds
2017-12-27 17:38:37.362599 INFO bathroom_light_day: Light on because motion is on
But sometimes even if it detects motion brightness is set to 30 and it just turn off light. Like this:
2017-12-27 17:18:58.747447 INFO bathroom_light_day: Light on because motion is on
2017-12-27 17:26:33.546852 INFO bathroom_light_day: Light on because motion is on
2017-12-27 17:26:46.029043 INFO bathroom_light_day: Set brightness to 30 and turn off light in 10 seconds
2017-12-27 17:26:56.026499 INFO bathroom_light_day: Light turn off
2017-12-27 17:26:56.227448 INFO bathroom_light_day: reset handle, because light.bathroom was turned off
Why it behaves like this?
import appdaemon.appapi as appapi
class MotionLight(appapi.AppDaemon):
def initialize(self):
self.handle = None
if "sensor" in self.args:
self.listen_state(self.motion_on, self.args["sensor"], new="on")
self.listen_state(self.motion_off, self.args["sensor"], new="off", duration=self.args["delay"])
else:
self.log("No sensor specified, doing nothing")
if "entity_id" in self.args:
self.listen_state(self.off, self.args["entity_id"])
else:
self.log("No light specified, doing nothing")
def off(self, entity, attribute, old, new, kwargs):
if self.get_state(self.args["entity_id"]) == "off":
self.log("reset handle, because {} was turned off".format(self.args["entity_id"]))
self.cancel_timer(self.handle)
self.handle = None
def motion_on(self, entity, attribute, old, new, kwargs):
self.log("Light on because motion is on")
self.turn_on(self.args["entity_id"], brightness = int(self.args["brightness"]))
self.handle = None
def motion_off(self, entity, attribute, old, new, kwargs):
if self.get_state(self.args["entity_id"]) == "on":
self.log("Set brightness to 30 and turn off light in 10 seconds")
self.call_service("light/turn_on", entity_id = (self.args["entity_id"]), brightness = 30)
self.handle = self.run_in(self.light_off, 10)
def light_off(self, kwargs):
self.log("Light turn off")
self.turn_off(self.args["entity_id"])
bathroom_light_day:
module: bathroom_light
class: MotionLight
sensor: binary_sensor.motion_sensor_xxxx
entity_id: light.bathroom
constrain_start_time: '07:00:00'
constrain_end_time: '20:59:59'
delay: 100
brightness: 255
