Cannot access /config folder anymore
I’ve got a strange problem: I cannot get access to my config folder anymore, neither by smb (by using the samba share add-on) nor by the integrated file editor. So, I cannot amend or change my configuration files at the moment.
Apart from that, Home Assistant Core runs like a charm, particularly the automations are working. I have also access to other folders like /backup oder /media. Only access to /config folder does not work.
I have no idea what have caused the access restriction. Can anybody help me to get access to my config folder again?
(I have a rhasberry Pi 3+ with Home Assistant OS 7.6 and Home Assistant Core 3.8)
Same here! Everything was fine until I rolled back from 2022.4.7 to 4.6. Still exploring fixes but welcome to suggestions.
Got it working again. Despite the Samba service showing as running after a reboot, I restarted it and enabled watchdog. Was able to connect to the config share after that.
ok, I got it working again, too. First, I went to version 2022.4.7 but to no avail. Then, I deinstalled and reinstalled the samba add-on. That solved the problem.
I also think that my access problems started when I rolled back from 2022.4.4 to 2022.3.8 due to Zigbee problems.
