Hello!
i’m pretty clueless right now. I cannot use the File Editor If I go through Nginx. I’ve got 504 Gateway Time-out in the Iframe. I can access to it from local IP. I disabled firefox browser protection.
I tried with a fresh browser, different Nginx config etc. Any clue would be appreciated!
In File Editor log :
INFO:2023-10-05 15:33:33,214:hass_configurator.configurator:127.0.0.1 - "GET / HTTP/1.1" 200 -
INFO:2023-10-05 15:34:03,282:hass_configurator.configurator:127.0.0.1 - "GET / HTTP/1.1" 200 -
But first, this is my actual configuration
Home Assistant 2023.9.3 (supervised on debian 12)
Supervisor 2023.10.0
** Interface : 20230911.0 - latest**
Network :
3 virtual network card with different VLAN (VLAN 1, Wifi and IOT). The VLAN1 network card, is the default one.
in configuration.yaml
http:
use_x_forwarded_for: true
trusted_proxies:
- 192.168.xxx.3 # IP of my Nginx server
- 172.30.32.0/23 # IP subnet from internal HAS Docker
- 127.0.0.1 (not sure if needed)
Docker containers
For my nginx :
- Nginx Proxy Manager in a Docker in a DMZ VLAN
HAS nginx conf. (I tried a lot of stuff). Websocket activated
proxy_buffering off;
location / {
add_header X-Robots-Tag "noindex, nofollow, nosnippet, noarchive";
proxy_pass http://192.168.xxx.52:8123;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "upgrade";
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
location /api { # Home Assistant API SSL reverse proxy
proxy_pass http://192.168.xxx.52:8123/api;
location /auth { # Home Assistant API SSL reverse proxy
proxy_pass http://192.168.xxx.52:8123/auth;
My Nginx log
[05/Oct/2023:12:50:59 -0700] - 200 200 - GET https home.exemple.com "/core_configurator/ingress?auth_callback=1&code=2fb00fa68ca043iophjswfoiahs96939141f&state=eyJoYXNzVXJsIjoiaHR0cHM6posjdfgposjdfpoddsjfpozovL2hvbWUuamVkZHVmZi5jb20vIn0%3D&storeToken=true" [Client 192.168.xxx.250] [Length 3126] [Gzip 2.91] [Sent-to 192.168.xxx.52] "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/117.0.0.0 Safari/537.36 Edg/117.0.2045.55" "-"
[05/Oct/2023:12:50:59 -0700] - 200 200 - POST https home.exemple.com "/auth/token" [Client 192.168.xxx.250] [Length 344] [Gzip -] [Sent-to 192.168.xxx.52] "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/117.0.0.0 Safari/537.36 Edg/117.0.2045.55" "https://home.exemple.com/core_configurator/ingress?auth_callback=1&code=2fb00fa68ca043iophjswfoiahs96939141f&state=eyJoYXNzVXJsIjoiaHR0cHM6posjdfgposjdfpoddsjfpozovL2hvbWUuamVkZHVmZi5jb20vIn0%3D&storeToken=true"
[05/Oct/2023:12:50:59 -0700] - 200 200 - GET https home.exemple.com "/manifest.json" [Client 192.168.xxx.250] [Length 933] [Gzip -] [Sent-to 192.168.xxx.52] "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/117.0.0.0 Safari/537.36 Edg/117.0.2045.55" "https://home.exemple.com/core_configurator/ingress?auth_callback=1&code=2fb00fa68ca043iophjswfoiahs96939141f&state=eyJoYXNzVXJsIjoiaHR0cHM6posjdfgposjdfpoddsjfpozovL2hvbWUuamVkZHVmZi5jb20vIn0%3D&storeToken=true"
[05/Oct/2023:12:51:00 -0700] - 200 200 - GET https home.exemple.com "/api/hassio/app/entrypoint.js" [Client 192.168.xxx.250] [Length 258] [Gzip -] [Sent-to 192.168.xxx.52] "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/117.0.0.0 Safari/537.36 Edg/117.0.2045.55" "https://home.exemple.com/core_configurator/ingress"
[05/Oct/2023:12:51:09 -0700] - 101 101 - GET https home.exemple.com "/api/websocket" [Client 192.168.xxx.250] [Length 71956] [Gzip -] [Sent-to 192.168.xxx.52] "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/118.0" "-"
[05/Oct/2023:12:51:09 -0700] - 101 101 - GET https home.exemple.com "/api/websocket" [Client 192.168.xxx.250] [Length 51] [Gzip -] [Sent-to 192.168.xxx.52] "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/118.0" "-"
[05/Oct/2023:12:51:09 -0700] - 200 200 - GET https home.exemple.com "/core_configurator/ingress" [Client 192.168.xxx.250] [Length 3126] [Gzip 2.91] [Sent-to 192.168.xxx.52] "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/118.0" "-"
[05/Oct/2023:12:51:10 -0700] - 200 200 - GET https home.exemple.com "/api/hassio/app/entrypoint.js" [Client 192.168.xxx.250] [Length 258] [Gzip -] [Sent-to 192.168.xxx.52] "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/118.0" "https://home.exemple.com/core_configurator/ingress"
[05/Oct/2023:12:51:10 -0700] - 200 200 - GET https home.exemple.com "/service_worker.js" [Client 192.168.xxx.250] [Length 69429] [Gzip -] [Sent-to 192.168.xxx.52] "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/118.0" "-"
