This is by no means all of the log but I can’t post the whole thing due to character limits:
2018-11-07 14:52:42 WARNING (MainThread) [homeassistant.components.http] legacy_api_password support has been enabled. If you don’t require it, remove the ‘api_password’ from your http config.
2018-11-07 14:52:51 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=249 from 2018-11-07 06:01:19.967335)
2018-11-07 14:53:17 WARNING (MainThread) [homeassistant.setup] Setup of frontend is taking over 10 seconds.
2018-11-07 14:55:03 WARNING (MainThread) [hbmqtt.mqtt.protocol.handler] BrokerProtocolHandler Unhandled exception in reader coro: IncompleteReadError(‘0 bytes read on a total of 1 expected bytes’,)
2018-11-07 14:55:07 WARNING (MainThread) [hbmqtt.mqtt.protocol.handler] BrokerProtocolHandler Unhandled exception in reader coro: IncompleteReadError(‘0 bytes read on a total of 1 expected bytes’,)
2018-11-07 14:57:14 ERROR (MainThread) [homeassistant.core] Error doing job: Fatal error on transport TCPTransport (error status in uv_stream_t.shutdown callback)
OSError: [Errno 107] Socket not connected
2018-11-07 14:57:38 WARNING (MainThread) [homeassistant.components.weather] Setup of platform darksky is taking over 10 seconds.
2018-11-07 14:57:38 WARNING (MainThread) [homeassistant.components.sensor] Setup of platform template is taking over 10 seconds.
2018-11-07 14:57:38 WARNING (MainThread) [homeassistant.components.sensor] Setup of platform time_date is taking over 10 seconds.
2018-11-07 14:57:38 WARNING (MainThread) [homeassistant.components.sensor] Setup of platform systemmonitor is taking over 10 seconds.
2018-11-07 14:57:47 WARNING (MainThread) [hbmqtt.mqtt.protocol.handler] BrokerProtocolHandler Unhandled exception in reader coro: IncompleteReadError(‘0 bytes read on a total of 1 expected bytes’,)
And more. None of this makes much sense to me so I appreciate your help.
ConnectionResetError(104, ‘Connection reset by peer’))
2018-11-07 15:02:50 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File “/usr/local/lib/python3.6/site-packages/hbmqtt/broker.py”, line 343, in stream_connected
yield from self.client_connected(listener_name, StreamReaderAdapter(reader), StreamWriterAdapter(writer))
File “/usr/local/lib/python3.6/site-packages/hbmqtt/broker.py”, line 353, in client_connected
remote_address, remote_port = writer.get_peer_info()
File “/usr/local/lib/python3.6/site-packages/hbmqtt/adapters.py”, line 172, in get_peer_info
return extra_info[0], extra_info[1]
TypeError: ‘NoneType’ object is not subscriptable
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude:
longitude: -
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 205
# metric for Metric, imperial for Imperial
unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: Europe/London
customize: !include customize.yaml
mqtt:
password: hello
hassio:
# Show links to resources in log and frontend
# introduction:
#auth_providers:
# - type: homeassistant
# Uncomment next line if you want to enable legacy API password support
# - type: legacy_api_password
# homekit:
# Enables the frontend
frontend:
weather:
- platform: darksky
api_key:
# Enables configuration UI
config:
notify:
- name: Prowl
platform: prowl
api_key: !secret prowl_api
- name: neil_prowl
platform: prowl
api_key: !secret neil_prowl_api
- name: iPhone
platform: ios
target: !secret ios_ash_x_push_id
remote:
- platform: harmony
host: 10.0.1.27
http:
# Secrets are defined in the file secrets.yaml
api_password: !secret http_password
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
base_url: 10.0.1.32:8123
#base_url:
#ssl_certificate: /ssl/fullchain.pem
#ssl_key: /ssl/privkey.pem
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
# Optional, allows Home Assistant developers to focus on popular components.
# include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Enables a map showing the location of tracked devices
map:
# device_tracker:
# - platform: nmap_tracker
# hosts:
# - 10.0.1.63
# - 10.0.1.50
# - 10.0.1.141
# home_interval: 10
# exclude: 10.0.1.32
# Track the sun
sun:
# Google Calendar sensor integrsation
google:
client_id: !secret google_client_id
client_secret: !secret google_client_secret
# mqtt:
# broker: core-mosquitto
# username: !secret mqtt_username
# password: !secret mqtt_password
ring:
username: !secret ring_username
password: !secret ring_password
# Text to speech
tts:
- platform: google
panel_iframe:
configurator:
title: Configurator
icon: mdi:wrench
url: http://10.0.1.32:3218
tasmoadmin:
title: TasmoAdmin
icon: mdi:lightbulb-on
url: http://10.0.1.32:9541
ide:
title: IDE
icon: mdi:code-braces
url: http://10.0.1.32:8321
mdiindex:
title: MDI Icon Index
icon: mdi:vector-square
url: https://cdn.rawgit.com/james-fry/home-assistant-mdi/efd95d7a/home-assistant-mdi.html
# Cloud
cloud:
google_actions:
filter:
include_entities:
- script.lounge_tv_off
- script.garage_door
exclude_entities:
- switch.garage_door_opener
include_domains:
- script
group: !include groups.yaml
alert: !include alerts.yaml
input_number: !include input_slider.yaml
#harmony_control: !include harmony_control.yaml
script: !include scripts.yaml
binary_sensor: !include binary_sensor.yaml
switch: !include switch.yaml
#arlo: !include arlo.yaml
sensor: !include sensor.yaml
input_boolean: !include booleans.yaml
input_select: !include input_select.yaml
ios: !include ios.yaml
try removing mqtt from config.yaml. That’s what i did prior to reboot. Follow these steps if you can get your front-end backup. Have you got a backup you can recover from?
if you use themes then remove frontend: from your configuration.yaml. That caused an error after I upgraded to 0.81. Also remove the mqtt: from your configuration.yaml
I removed mqtt: from config.yaml and I’m back in! Phew!
However, when attempting to configure MQTT in Integrations I get ‘cannot connect to broker’.
What should I be entering here?
What user name and password?
I read this post but I’m not clear how to set the MQTT user and password in users.
I have three users there: me and two Homeassistant users (sys generated), that can’t be removed.
If I create another ‘fictitious’ user, how does it link through to being the MQTT user and password?
All of my devices use my home assistant user name and password as the MQTT password (which previously matched the Mosquitto username and password) but that doesn’t work with configuring MQTT in Integrations.
Almost there. I just need a final nudge in the right direction from you guys.
Yeah it works for me. Try it out. I still get “Socket error on client <unknown>, disconnecting” but I can switch stuff from the frontend like it used to be so I’m happy with that.
The Socket error on client <unknown>, disconnecting comes from devices where you have to set the new username and password because homeassistant as username isn’t allowed anymore. Just found that out
