Cannot access GUI - running Hassio on Ubuntu in docker
Hi All,
coupe of days ago my Ubuntu VM was forced rebooted. When it came back up the gui was not accessible. Tried a bunch of things including installed from scratch (gui was accessible) restoring from snapshot (still accessible) but the cloud integration was not working. I remove the cloud file from the config and reboot. Gui is no longer accessible. Looks like something changed that is causing the GUI to not work. Google a whole bunch and found this topic.
I am a noob with docker but learning fast. I tried removing the supervisor container and reinstalling but that does not work also.
Appreciate any help. Logs attached from the reboot this am when the gui stopped.
2020-04-11 07:14:11 WARNING (Thread-8) [pychromecast.socket_client] [192.168.4.203:8009] Heartbeat timeout, resetting connection
2020-04-11 07:14:41 ERROR (Thread-8) [pychromecast.socket_client] [192.168.4.203:8009] Failed to connect, retrying in 5.0s
2020-04-11 07:39:40 ERROR (MainThread) [homeassistant.components.cloud.http_api] Unexpected error processing request for /api/cloud/login
  File "/usr/src/homeassistant/homeassistant/components/cloud/http_api.py", line 129, in error_handler
    result = await handler(view, request, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 50, in wrapper
    result = await method(view, request, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/components/cloud/http_api.py", line 196, in post
    await cloud.login(data["email"], data["password"])
  File "/usr/local/lib/python3.7/site-packages/hass_nabucasa/__init__.py", line 179, in login
    await self.start()
  File "/usr/local/lib/python3.7/site-packages/hass_nabucasa/__init__.py", line 237, in start
    await self.client.logged_in()
  File "/usr/src/homeassistant/homeassistant/components/cloud/client.py", line 120, in logged_in
    gconf.async_enable_local_sdk()
  File "/usr/src/homeassistant/homeassistant/components/google_assistant/helpers.py", line 210, in async_enable_local_sdk
    self.hass, DOMAIN, "Local Support", webhook_id, self._handle_local_webhook,
  File "/usr/src/homeassistant/homeassistant/components/webhook/__init__.py", line 33, in async_register
    raise ValueError("Handler is already defined!")
ValueError: Handler is already defined!
2020-04-11 07:39:58 ERROR (MainThread) [homeassistant.components.cloud.http_api] Unexpected error processing request for /api/cloud/login
  File "/usr/local/lib/python3.7/site-packages/hass_nabucasa/__init__.py", line 178, in login
    await self.run_executor(self.auth.login, email, password)
  File "/usr/local/lib/python3.7/site-packages/hass_nabucasa/auth.py", line 136, in login
    cognito = self._authenticate(email, password)
  File "/usr/local/lib/python3.7/site-packages/hass_nabucasa/auth.py", line 195, in _authenticate
    assert not self.cloud.is_logged_in, "Cannot login if already logged in."
AssertionError: Cannot login if already logged in.
2020-04-11 07:48:47 ERROR (MainThread) [homeassistant.components.cloud.http_api] Unexpected error processing request for /api/cloud/login
2020-04-11 07:49:38 ERROR (Thread-9) [pychromecast.socket_client] [192.168.4.207:8009] Failed to connect. No retries.
2020-04-11 07:49:41 ERROR (Thread-10) [pychromecast.socket_client] [192.168.4.204:8009] Failed to connect. No retries.
2020-04-11 07:49:41 ERROR (Thread-11) [pychromecast.socket_client] [192.168.4.206:8009] Failed to connect: [Errno 113] Host is unreachable. aborting due to stop signal.
2020-04-11 07:54:15 INFO (MainThread) [homeassistant.bootstrap] Config directory: /config
2020-04-11 07:54:17 INFO (SyncWorker_0) [homeassistant.loader] Loaded breaking_changes from custom_components.breaking_changes
2020-04-11 07:54:18 INFO (SyncWorker_2) [homeassistant.loader] Loaded hacs from custom_components.hacs
2020-04-11 07:54:18 INFO (SyncWorker_5) [homeassistant.loader] Loaded weather from homeassistant.components.weather
2020-04-11 07:54:18 INFO (SyncWorker_4) [homeassistant.loader] Loaded alarm_control_panel from homeassistant.components.alarm_control_panel
2020-04-11 07:54:18 INFO (SyncWorker_0) [homeassistant.loader] Loaded light from homeassistant.components.light
2020-04-11 07:54:18 INFO (SyncWorker_1) [homeassistant.loader] Loaded group from homeassistant.components.group
2020-04-11 07:54:19 INFO (SyncWorker_5) [homeassistant.loader] Loaded scene from homeassistant.components.scene
2020-04-11 07:54:19 INFO (SyncWorker_3) [homeassistant.loader] Loaded input_number from homeassistant.components.input_number
2020-04-11 07:54:19 INFO (SyncWorker_2) [homeassistant.loader] Loaded binary_sensor from homeassistant.components.binary_sensor
2020-04-11 07:54:19 INFO (SyncWorker_0) [homeassistant.loader] Loaded sensor from homeassistant.components.sensor
2020-04-11 07:54:19 INFO (SyncWorker_6) [homeassistant.loader] Loaded input_text from homeassistant.components.input_text
2020-04-11 07:54:19 INFO (SyncWorker_7) [homeassistant.loader] Loaded automation from homeassistant.components.automation
2020-04-11 07:54:19 INFO (SyncWorker_4) [homeassistant.loader] Loaded device_automation from homeassistant.components.device_automation
2020-04-11 07:54:20 INFO (SyncWorker_3) [homeassistant.loader] Loaded webhook from homeassistant.components.webhook
2020-04-11 07:54:20 INFO (SyncWorker_2) [homeassistant.loader] Loaded http from homeassistant.components.http
2020-04-11 07:54:20 INFO (SyncWorker_7) [homeassistant.loader] Loaded homeassistant from homeassistant.components.homeassistant
2020-04-11 07:54:20 INFO (MainThread) [homeassistant.setup] Setting up homeassistant
2020-04-11 07:54:20 INFO (MainThread) [homeassistant.setup] Setup of domain homeassistant took 0.0 seconds.
2020-04-11 07:54:20 INFO (SyncWorker_8) [homeassistant.loader] Loaded persistent_notification from homeassistant.components.persistent_notification
2020-04-11 07:54:20 INFO (MainThread) [homeassistant.setup] Setting up persistent_notification
2020-04-11 07:54:20 INFO (MainThread) [homeassistant.setup] Setup of domain persistent_notification took 0.0 seconds.
2020-04-11 07:54:20 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-04-11 07:54:21 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for breaking_changes which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-04-11 07:54:21 INFO (SyncWorker_2) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api
2020-04-11 07:54:21 INFO (SyncWorker_5) [homeassistant.loader] Loaded discovery from homeassistant.components.discovery
2020-04-11 07:54:21 INFO (SyncWorker_9) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook
2020-04-11 07:54:21 INFO (SyncWorker_0) [homeassistant.loader] Loaded plex from homeassistant.components.plex
2020-04-11 07:54:21 INFO (SyncWorker_6) [homeassistant.loader] Loaded lovelace from homeassistant.components.lovelace
2020-04-11 07:54:21 INFO (SyncWorker_2) [homeassistant.loader] Loaded map from homeassistant.components.map
2020-04-11 07:54:21 INFO (SyncWorker_4) [homeassistant.loader] Loaded speedtestdotnet from homeassistant.components.speedtestdotnet
2020-04-11 07:54:21 INFO (SyncWorker_3) [homeassistant.loader] Loaded media_player from homeassistant.components.media_player
2020-04-11 07:54:21 INFO (SyncWorker_7) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend
2020-04-11 07:54:21 INFO (SyncWorker_1) [homeassistant.loader] Loaded config from homeassistant.components.config
2020-04-11 07:54:21 INFO (SyncWorker_5) [homeassistant.loader] Loaded cover from homeassistant.components.cover
2020-04-11 07:54:21 INFO (SyncWorker_2) [homeassistant.loader] Loaded ecobee from homeassistant.components.ecobee
2020-04-11 07:54:21 INFO (SyncWorker_1) [homeassistant.loader] Loaded esphome from homeassistant.components.esphome
2020-04-11 07:54:21 INFO (SyncWorker_0) [homeassistant.loader] Loaded zwave from homeassistant.components.zwave
2020-04-11 07:54:21 INFO (SyncWorker_3) [homeassistant.loader] Loaded cast from homeassistant.components.cast
2020-04-11 07:54:21 INFO (SyncWorker_2) [homeassistant.loader] Loaded camera from homeassistant.components.camera
2020-04-11 07:54:21 INFO (SyncWorker_6) [homeassistant.loader] Loaded system_health from homeassistant.components.system_health
2020-04-11 07:54:21 INFO (SyncWorker_8) [homeassistant.loader] Loaded tts from homeassistant.components.tts
2020-04-11 07:54:21 INFO (SyncWorker_0) [homeassistant.loader] Loaded hassio from homeassistant.components.hassio
2020-04-11 07:54:21 INFO (SyncWorker_3) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder
2020-04-11 07:54:21 INFO (SyncWorker_5) [homeassistant.loader] Loaded life360 from homeassistant.components.life360
2020-04-11 07:54:21 INFO (SyncWorker_1) [homeassistant.loader] Loaded nest from homeassistant.components.nest
2020-04-11 07:54:21 INFO (SyncWorker_4) [homeassistant.loader] Loaded mobile_app from homeassistant.components.mobile_app
2020-04-11 07:54:21 INFO (SyncWorker_0) [homeassistant.loader] Loaded coronavirus from homeassistant.components.coronavirus
2020-04-11 07:54:21 INFO (SyncWorker_2) [homeassistant.loader] Loaded input_select from homeassistant.components.input_select
2020-04-11 07:54:21 INFO (SyncWorker_8) [homeassistant.loader] Loaded cloud from homeassistant.components.cloud
2020-04-11 07:54:21 INFO (SyncWorker_0) [homeassistant.loader] Loaded switch from homeassistant.components.switch
2020-04-11 07:54:21 INFO (SyncWorker_5) [homeassistant.loader] Loaded panel_iframe from homeassistant.components.panel_iframe
2020-04-11 07:54:21 INFO (SyncWorker_4) [homeassistant.loader] Loaded device_tracker from homeassistant.components.device_tracker
2020-04-11 07:54:21 INFO (SyncWorker_3) [homeassistant.loader] Loaded sun from homeassistant.components.sun
2020-04-11 07:54:21 INFO (SyncWorker_2) [homeassistant.loader] Loaded updater from homeassistant.components.updater
2020-04-11 07:54:21 INFO (SyncWorker_8) [homeassistant.loader] Loaded proximity from homeassistant.components.proximity
2020-04-11 07:54:21 INFO (SyncWorker_5) [homeassistant.loader] Loaded logger from homeassistant.components.logger
2020-04-11 07:54:21 INFO (SyncWorker_6) [homeassistant.loader] Loaded script from homeassistant.components.script
2020-04-11 07:54:21 INFO (SyncWorker_3) [homeassistant.loader] Loaded panel_custom from homeassistant.components.panel_custom
2020-04-11 07:54:21 INFO (SyncWorker_1) [homeassistant.loader] Loaded mqtt from homeassistant.components.mqtt
2020-04-11 07:54:21 INFO (SyncWorker_2) [homeassistant.loader] Loaded wled from homeassistant.components.wled
2020-04-11 07:54:21 INFO (SyncWorker_4) [homeassistant.loader] Loaded history from homeassistant.components.history
2020-04-11 07:54:21 INFO (SyncWorker_6) [homeassistant.loader] Loaded person from homeassistant.components.person
2020-04-11 07:54:21 INFO (SyncWorker_0) [homeassistant.loader] Loaded ifttt from homeassistant.components.ifttt
2020-04-11 07:54:21 INFO (SyncWorker_3) [homeassistant.loader] Loaded zone from homeassistant.components.zone
2020-04-11 07:54:21 INFO (SyncWorker_8) [homeassistant.loader] Loaded notify from homeassistant.components.notify
2020-04-11 07:54:21 INFO (SyncWorker_5) [homeassistant.loader] Loaded api from homeassistant.components.api
2020-04-11 07:54:21 INFO (SyncWorker_1) [homeassistant.loader] Loaded auth from homeassistant.components.auth
2020-04-11 07:54:21 INFO (SyncWorker_4) [homeassistant.loader] Loaded onboarding from homeassistant.components.onboarding
2020-04-11 07:54:21 INFO (SyncWorker_9) [homeassistant.loader] Loaded envisalink from homeassistant.components.envisalink
2020-04-11 07:54:21 INFO (SyncWorker_0) [homeassistant.loader] Loaded search from homeassistant.components.search
2020-04-11 07:54:21 INFO (SyncWorker_8) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log
2020-04-11 07:54:21 INFO (SyncWorker_7) [homeassistant.loader] Loaded influxdb from homeassistant.components.influxdb
2020-04-11 07:54:21 INFO (MainThread) [homeassistant.bootstrap] Setting up {'system_log', 'logger'}
2020-04-11 07:54:21 INFO (MainThread) [homeassistant.setup] Setting up logger
/usr/local/lib/python3.7/site-packages/sqlalchemy/connectors/pyodbc.py:79: SAWarning: No driver name specified; this is expected by PyODBC when using DSN-less connections
  "No driver name specified; "
2020-04-11 07:54:34 WARNING (MainThread) [homeassistant.setup] Setup of recorder is taking over 10 seconds.
2020-04-11 07:58:45 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (pyodbc.OperationalError) ('08S01', '[08S01] [FreeTDS][SQL Server]Unable to connect: Adaptive Server is unavailable or does not exist (20009) (SQLDriverConnect)')
(Background on this error at: http://sqlalche.me/e/e3q8) (retrying in 3 seconds)
2020-04-11 08:03:09 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (pyodbc.OperationalError) ('08S01', '[08S01] [FreeTDS][SQL Server]Unable to connect: Adaptive Server is unavailable or does not exist (20009) (SQLDriverConnect)')
2020-04-11 08:07:34 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (pyodbc.OperationalError) ('08S01', '[08S01] [FreeTDS][SQL Server]Unable to connect: Adaptive Server is unavailable or does not exist (20009) (SQLDriverConnect)')
2020-04-11 08:11:58 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (pyodbc.OperationalError) ('08S01', '[08S01] [FreeTDS][SQL Server]Unable to connect: Adaptive Server is unavailable or does not exist (20009) (SQLDriverConnect)')
2020-04-11 08:16:22 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (pyodbc.OperationalError) ('08S01', '[08S01] [FreeTDS][SQL Server]Unable to connect: Adaptive Server is unavailable or does not exist (20009) (SQLDriverConnect)')
2020-04-11 08:20:46 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (pyodbc.OperationalError) ('08S01', '[08S01] [FreeTDS][SQL Server]Unable to connect: Adaptive Server is unavailable or does not exist (20009) (SQLDriverConnect)')
2020-04-11 08:25:10 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (pyodbc.OperationalError) ('08S01', '[08S01] [FreeTDS][SQL Server]Unable to connect: Adaptive Server is unavailable or does not exist (20009) (SQLDriverConnect)')
2020-04-11 08:29:35 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (pyodbc.OperationalError) ('08S01', '[08S01] [FreeTDS][SQL Server]Unable to connect: Adaptive Server is unavailable or does not exist (20009) (SQLDriverConnect)')
2020-04-11 08:33:59 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (pyodbc.OperationalError) ('08S01', '[08S01] [FreeTDS][SQL Server]Unable to connect: Adaptive Server is unavailable or does not exist (20009) (SQLDriverConnect)')
2020-04-11 09:00:03 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (pyodbc.OperationalError) ('08S01', '[08S01] [FreeTDS][SQL Server]Unable to connect: Adaptive Server is unavailable or does not exist (20009) (SQLDriverConnect)')
2020-04-11 09:00:48 ERROR (MainThread) [homeassistant.setup] Setup failed for recorder: Integration failed to initialize.
2020-04-11 09:03:12 WARNING (MainThread) [homeassistant.components.group] The 'view' option (with value 'True') is deprecated, please remove it from your configuration. This option will become invalid in version 0.107.0
2020-04-11 09:03:13 WARNING (MainThread) [homeassistant.components.group] The 'view' option (with value 'True') is deprecated, please remove it from your configuration. This option will become invalid in version 0.107.0
2020-04-11 09:03:13 WARNING (MainThread) [homeassistant.components.group] The 'view' option (with value 'False') is deprecated, please remove it from your configuration. This option will become invalid in version 0.107.0
2020-04-11 09:03:32 WARNING (MainThread) [homeassistant.setup] Setup of envisalink is taking over 10 seconds.
2020-04-11 09:03:32 WARNING (MainThread) [homeassistant.setup] Setup of group is taking over 10 seconds.
2020-04-11 09:03:32 WARNING (MainThread) [homeassistant.setup] Setup of input_number is taking over 10 seconds.
2020-04-11 09:03:32 WARNING (MainThread) [homeassistant.setup] Setup of influxdb is taking over 10 seconds.
2020-04-11 09:03:39 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of history. Setup failed for dependencies: recorder
2020-04-11 09:03:39 ERROR (MainThread) [homeassistant.setup] Setup failed for history: Could not set up all dependencies.
2020-04-11 09:03:39 ERROR (MainThread) [pyenvisalink.envisalink_base_client] Unable to connect to envisalink. Reconnecting...
2020-04-11 09:03:39 ERROR (MainThread) [homeassistant.components.envisalink] Could not establish a connection with the Envisalink- retrying...
2020-04-11 09:04:02 WARNING (MainThread) [homeassistant.setup] Setup of input_select is taking over 10 seconds.
2020-04-11 09:04:02 WARNING (MainThread) [homeassistant.setup] Setup of zone is taking over 10 seconds.
2020-04-11 09:04:02 WARNING (MainThread) [homeassistant.setup] Setup of updater is taking over 10 seconds.
2020-04-11 09:04:02 WARNING (MainThread) [homeassistant.setup] Setup of input_text is taking over 10 seconds.
2020-04-11 09:04:05 WARNING (MainThread) [homeassistant.components.scene] Setup of scene platform homeassistant is taking over 10 seconds.
2020-04-11 09:04:05 WARNING (MainThread) [homeassistant.setup] Setup of person is taking over 10 seconds.
2020-04-11 09:04:05 WARNING (MainThread) [homeassistant.setup] Setup of config is taking over 10 seconds.
2020-04-11 09:04:05 WARNING (MainThread) [homeassistant.components.alarm_control_panel] Setup of alarm_control_panel platform manual is taking over 10 seconds.
2020-04-11 09:04:16 ERROR (MainThread) [homeassistant.components.updater] Could not contact Home Assistant Update to check for updates
2020-04-11 09:04:18 ERROR (MainThread) [homeassistant.components.updater] Error fetching Home Assistant update data:
2020-04-11 09:04:18 WARNING (MainThread) [homeassistant.components.met.weather] Loading Met.no via platform config is deprecated
2020-04-11 09:04:25 WARNING (MainThread) [homeassistant.components.weather] Setup of weather platform darksky is taking over 10 seconds.
2020-04-11 09:04:26 WARNING (MainThread) [homeassistant.components.weather] Setup of weather platform met is taking over 10 seconds.
2020-04-11 09:04:28 ERROR (Thread-9) [pychromecast.socket_client] [192.168.4.204:8009] Failed to connect, retrying in 5.0s
2020-04-11 09:04:29 ERROR (Thread-11) [pychromecast.socket_client] [192.168.4.207:8009] Failed to connect, retrying in 5.0s
2020-04-11 09:04:35 ERROR (MainThread) [pyenvisalink.envisalink_base_client] Unable to connect to envisalink. Reconnecting...
2020-04-11 09:04:35 ERROR (MainThread) [homeassistant.components.envisalink] Could not establish a connection with the Envisalink- retrying...
2020-04-11 09:04:35 WARNING (MainThread) [homeassistant.components.automation] The 'hide_entity' option (with value 'True') is deprecated, please remove it from your configuration. This option will become invalid in version 0.107
2020-04-11 09:04:36 WARNING (MainThread) [homeassistant.components.automation] The 'hide_entity' option (with value 'True') is deprecated, please remove it from your configuration. This option will become invalid in version 0.107
2020-04-11 09:04:38 WARNING (MainThread) [homeassistant.components.binary_sensor] Setup of binary_sensor platform mqtt is taking over 10 seconds.
--- Logging error ---
  File "/usr/local/lib/python3.7/logging/__init__.py", line 1025, in emit
    msg = self.format(record)
  File "/usr/local/lib/python3.7/logging/__init__.py", line 869, in format
    return fmt.format(record)
  File "/usr/local/lib/python3.7/site-packages/colorlog/colorlog.py", line 123, in format
    message = super(ColoredFormatter, self).format(record)
  File "/usr/local/lib/python3.7/logging/__init__.py", line 608, in format
    record.message = record.getMessage()
  File "/usr/local/lib/python3.7/logging/__init__.py", line 369, in getMessage
    msg = msg % self.args
TypeError: not all arguments converted during string formatting
Call stack:
  File "/usr/local/lib/python3.7/runpy.py", line 193, in _run_module_as_main
    "__main__", mod_spec)
  File "/usr/local/lib/python3.7/runpy.py", line 85, in _run_code
    exec(code, run_globals)
  File "/usr/src/homeassistant/homeassistant/__main__.py", line 350, in <module>
    sys.exit(main())
  File "/usr/src/homeassistant/homeassistant/__main__.py", line 342, in main
    exit_code = asyncio.run(setup_and_run_hass(config_dir, args))
  File "/usr/local/lib/python3.7/asyncio/runners.py", line 43, in run
    return loop.run_until_complete(main)
  File "/usr/local/lib/python3.7/asyncio/base_events.py", line 570, in run_until_complete
    self.run_forever()
  File "/usr/local/lib/python3.7/asyncio/base_events.py", line 538, in run_forever
    self._run_once()
  File "/usr/local/lib/python3.7/asyncio/base_events.py", line 1782, in _run_once
    handle._run()
  File "/usr/local/lib/python3.7/asyncio/events.py", line 88, in _run
    self._context.run(self._callback, *self._args)
  File "/usr/src/homeassistant/homeassistant/components/template/cover.py", line 123, in async_setup_platform
    "Must specify at least one of %s" or "%s", OPEN_ACTION, POSITION_ACTION
Message: 'Must specify at least one of %s'
Arguments: ('open_cover', 'set_cover_position')
Call stack:
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
I was able to fix it. I was using the wrong url to reinstall Hassio
