Let me first explain my network setup:
Internet ------ Modem/Router ------- Mesh Router ------- all my wifi/wired clients
TV Decoder
The WAN side of the Modem/Router has a DHCP address assigned by the provider that never changes, so no need for DDNS solutions (yay).
The Modem/Router is provided by the ISP (mandatory) and the TV Decoder box (also provided by ISP) is directly connected to the Modem/Router. The decoder HAS to be connected DIRECTLY to the Modem/Router for additional functions like tv-guide to work. This has been extensively documented on local forums and has been repeatedly confirmed by the ISP. No way around it.
Because the ISP’s Modem/Router has limited functions and can only be configured using the ISP’s portal, I have my own Mesh router to provide a WiFi signal to my home.
How do I have it configured:
Modem/router:
- Modem/Router WAN: Public IP (consider this static)
- Modem/Router LAN: 192.168.0.1, with DHCP active for the 192.168.0.2 → 192.168.0.100 range
- Port forwarding: 8123->8123 to 192.168.0.205
Mesh router
- Mesh router: 192.168.0.205 static, with DHCP active for the 192.168.68.x range (255.255.255.0)
- Port forwarding: 8123->8123 to RPI
This works great when I run HA on port 8123 on the RPI.
However, my company network blocks outgoing 8123, so I cannot acces my HA from work.Would be fixed if I could use port 80 WAN-side of the Modem/Router
I tried two this, both of them unsuccesfull:
- Change the port forwarding on the Modem/Router to 80->8123
- Run HA on the PI on port 80, change port forwarding on Router/Modem and Mesh Router so it’s all port 80 from start to end.
Both scenario’s cause the infamous “invalid client id or redirect uri”-error. It also throws “Login attempt or request with invalid authentication from 192.168.0.1” on HA.
So everything works fine when using port 8123 end-to-end, but not when using port mapping or when running HA on port 80.
Tried with different browsers and even systems, without success. In both scenario’s I can access HA from the local network.
System Health
arch armv7l chassis dev false docker true docker_version 19.03.12 hassio true host_os Raspbian GNU/Linux 10 (buster) installation_type Home Assistant Supervised os_name Linux os_version 4.19.118-v7l+ python_version 3.7.7 supervisor 228 timezone Europe/Brussels version 0.111.4 virtualenv false
